Bargain Tormek t3 needs help
Forum topic by jeffwedekind posted 06-16-2015 07:01 PM 919 views 0 times favorited 3 replies Add to Favorites Watch
View jeffwedekind's profile
jeffwedekind
144 posts in 2865 days
06-16-2015 07:01 PM
Topic tags/keywords: tormek grinder sharpening
Hi jocks,
I was at a rockler store this past week and the mngr put a Tormek t3 on the clearance table for $99..
I picked it up and ran to the check stand. Like so many of us I need serious help with sharpening, and hope(d) this would be my answer.
Here’s the rub… This thing has all the normal Tormek goodies/possibilities, but man is it built CHEAP. My main concern is the instability of the tool rest arms. They are set into plastic tubes that flexes under very slight pressure, this basically renders the thing useless. (in fact the new t4 is the same machine with the addition of a cast top that resolves this issue)
So I have two choices that I’m hoping you guys can help with.
1 return it and move on, or,
2 come up with a good modification to fix the stability issue. Google search comes up empty for a work around.
So far the only thought I have is to reinforce the top with plywood ….
Thanks for any ideas or advice
Here are a couple pics demonstrating the issue/difference.
-- Jeff, eastern Wa
3 replies so far
View Bill White's profile
Bill White
5101 posts in 4133 days
#1 posted 06-16-2015 08:35 PM
Return it and move on. Not enough time in life to deal with poor design.
Bill
-- bill@magraphics.us
View Bluepine38's profile
Bluepine38
3379 posts in 3258 days
#2 posted 06-17-2015 04:29 PM
Check the parts list on the t-4, if the cast top is less than the price difference betwee $99 and the t-4
buy the top. Personally, I would probably build a new top out a nice hardwood if possible, just to
customize it.
View dhazelton's profile
dhazelton
2789 posts in 2469 days
#3 posted 06-17-2015 05:55 PM
I see the T-4 is $399 on Amazon. If you could solve the issue and keep your extra three hundred you would be well ahead of the game.
