| Forum topic by Octavius | posted 71 days ago | 524 views | 1 time favorited | 13 replies | ![]() |
71 days ago |
Topic tags/keywords: craftsman stiff mechanism question Hi Folks, I’ve just bought an old Craftsman 113.298762. Both handwheels are split, probably because the mechanisms are very stiff. Applying forefinger pressure on that long wrench just barely moves the elevation. Of course, using some muscle I can move it from stop to stop but surely it should not be that stiff. I’m applying penetrating fluid (PB Blaster) to where it pivots but no luck so far in loosening it up.
Any ideas? Cheers |
71 days ago |
Hi! Hope this helps. :O) E mail me if I can help further. It is a good saw. Luck, |
71 days ago |
Smokey, Many thanks for the reply and the kind welcome. I presume you are talking about the rod that carries the wheel for the elevation, right? The one the wrench is attached to in the photo. Did you find it necessary to remove (and polish up) the other pivot point (that the pawl(?) is on)? Thanks for the tip about the dry graphite. Cheers |
71 days ago |
Octavis, tablesawalignment.com Smokey |
70 days ago |
OK, now I’m stuck. Here is the assembly, stripped down a bit more. I’ve removed the 2 e-clips on the elevator rod and the e-clip on the pawl component.
Can’t see how to separate them. Cheers |
70 days ago |
Octavis, |
69 days ago |
Smokey, Meantimes I’ve been de-rusting the table top and extensions with citric acid and paint remover- its coming along nicely and I’m very pleased with the progress. I measured the radial(?) runout with a dial indicator on the pulley shaft and it is zero! No in-and-out motion either. |
69 days ago |
The arbor pulls out of the housing. Remove the snap pully and key, remove the stop ring. I then used a softwood 2×4 and hammer to hit it on the pully side to knock the arbor and bearing out of the housing. I then used a 3 hooked puller to pull the next bearing off the end that did have the pully and housing on it. I bought new bearings at my local bearing store (be sure to take an old bearing with you as the size are on the side of the rase, and watch they don’t sell you a metric as the opposite diameter will be wrong). I replaced the bearings using a cutoff piece of PVC that had the same size od as the inside rase of the bearing. By being gentle I had no problem with r&r. Theonly place that gave me a problem was the outer bearing (the one next to the pully did not fit tight enought into the housing allowing a few thousandths of movement of the arbor. I ordered some wave washers but when I received them they were too thick so I peened the casting with a center punch and hammer. The result was no play and it works great so far. |
69 days ago |
Smokey, Thanks again for helping out. I am trying to separate part A from B (please see modified photo above). Sorry, I should have been more clear. It seems that A should pull off from B but they are really stuck together and I can’t even twist A around on the post. There doesn’t appear to be anywhere to put the legs of a bearing puller. Cheers |
68 days ago |
On mine there is a retaining ring on the end of the shaft on B that I removed and then was able to pull A off. Mine was not froze up thought, but I did soak it good with penetrating oil and worked it back and forth. It them came off real smooth. |
68 days ago |
Thanks Smokey. |
67 days ago |
OK, an update. I’ve successfully freed up part A from part B. It is now as loose as a goose and swings freely. That’s the good news. The potentially bad news that in doing so, the post (that A swings on and that is fixed in B) came out about 3/8”. I’ve banged it back in again so that it is flush again on the back of the main casting. I’m concerned that when the saw is in operation the post may come out and somehow be a safety concern. Hope I’m explaining this OK. Any thoughts? |
67 days ago |
Hmmm, the docs on a similar saw (here) seem to imply that post is just a press-fit into the casting; i.e. no setscrew or pin that would hold it in the casting. I think you’ve found the major reason for binding on the blade height mechanism – corrosion on the post and friction with part “A” in your photo above. I think it was frozen up so much that working the pivot back and forth moved the post enough to work it out of the casting slightly. As long as those parts move freely now, there should be no forces acting on the post to pull it out again. Make sure there is no play on that post with the swing arm now. Any play there will allow the blade to move slightly in relation to the table, making it impossible to keep the blade aligned with the miter slot. Others here have mentioned dry graphite for lube; I’ve also had good luck with spray on lithium lube. After drying, it doesn’t seem to attract any sawdust. -- "Find out what you cannot do and then go do it!" |
66 days ago |
EEngineer, Thanks for the clarification on the post corrosion – I can now put that out of my mind and move on. Yeah, I was not thinking of it on re-assembly but any play back and forth would be bad – I pretty sure I’m good to go, though. Thanks for the spray lithium lube suggestion – I’ll look out for it on my next visit to the hardware store. I went ahead with the dry graphite – only because I had some to hand – not the easiest stuff to apply – if it does go where you want it, it then just falls off. Ha! Cheers |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
