Air Compressor Question
Forum topic by Christopher Frank posted 06-16-2015 06:32 PM 873 views 0 times favorited 7 replies Add to Favorites Watch
View Christopher Frank's profile
Christopher Frank
11 posts in 3654 days
06-16-2015 06:32 PM
My small shop is looking to get a new air compressor, and we want to be able to run 2 DA’s at the same time. The DA’s use 17 CFM at 90psi Does that mean that I need a compressor that provides 34 CFM at 90 psi? Any help would be greatly appreciated.
Thanks!
Chris
7 replies so far
View JoeinGa's profile
JoeinGa
7732 posts in 1880 days
#1 posted 06-16-2015 07:18 PM
Running two DA’s will require a LOT of volume. So when you look at compressors, make sure you get one with a big enough airtank to handle what you’ll be doing. I’m thinking you’re gonna need something in the range of an 80 gallon tank (or bigger)
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1050 days
#2 posted 06-16-2015 07:20 PM
My small shop is looking to get a new air compressor, and we want to be able to run 2 DA s at the same time. The DA s use 17 CFM at 90psi Does that mean that I need a compressor that provides 34 CFM at 90 psi? Any help would be greatly appreciated.
Thanks!
Chris
- Christopher Frank
Yes. Also large enough supply lines to move that amount of air. I agree with JoeInGa that an 80 gallon tank is the way to go. This decreases how often the compressor has to run.
View timbertailor's profile
timbertailor
1594 posts in 1298 days
#3 posted 06-17-2015 02:42 PM
Two stage, 5HP, 120 gallon with a flow of 34CFM @ 90psi MINIMUM.
Not cheap and if it were me, I would get two units for redundancy and less wear and tear on the one motor and compressor.
View hotbyte's profile
hotbyte
989 posts in 2849 days
#4 posted 06-17-2015 03:16 PM
OK…curiosity is gonna kill the cat. DA = dual action sander???
timbertailor
#5 posted 06-17-2015 04:49 PM
- hotbyte
You got it. Dual Action
P.S. I know everyone is used to seeing air driven DA Sanders in a body shop but they are terribly inefficient.
I would consider using electric DA Sanders. Just as effective and use far less electricity.
hotbyte
#6 posted 06-17-2015 04:54 PM
runswithscissors
2603 posts in 1898 days
#7 posted 06-20-2015 04:01 AM
I agree with timbertailor. Except for a few very special applications (such as a nail gun or paint sprayer), I can’t understand the love so many people have for air tools.
