work bench questions
Forum topic by Betsy posted 68 days ago 342 views 0 times favorited 5 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 790 days
68 days ago
Topic tags/keywords: work bench dogs vise
I have a workbench that I use for my assembly and some hand tool work. This bench is in my bedroom shop in the house. Now I’m considering buying a good bench for the garage shop.
So naturally I’m looking for workbench types, etc. I’m really not interested in making my own bench because of the weight and time involved. It’s worth it to my to buy a ready made bench (knowing that I may still need to flatten the top – maybe).
I went to Highland Woodworking and I found this bench. (Not necessarily the one I’ll buy – but for show sake only.)
http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=2330
What I want to know is several things – what is with the funky looking vise set up? What’s the purpose of it being an L-shaped mechanism?
I understand using the end vise to move the bench dogs in and out to hold the differing lengths of wood. But still don’t understand the L-shape.
Next – and this is the most important question to me. It has to do with bench dogs. I know that the rectangular bench dogs are designed to pull down on the board so that the board is held firmly on the top without any give, but are the round dogs capable of doing the same grabbing? The round dogs in my current bench don’t seem to do any more than just hold – no pulling down. Not sure if this makes sense or not.
Thanks in advance.
16721 posts in 471 days
68 days ago
I’m not sure what you mean by “L” shape unless your talking about then end vice that allows for room to say put a drawer in the vise that has been assembled and still work on it. Round bench dogs are not real bench dogs in my mind they are just stops. Bench dogs because of there wedged shape can be tapped down to tighten your hold on your work. If it is with in you skill level you can have a better bench if you build it yourself and for less money.
View DaveR's profile
DaveR
1517 posts in 614 days
68 days ago
Betsy, the question about the L-shaped tail vise has come up before someplace. As I recall, the best reason given was that it provides a bit of counterbalance for the rest of the vise because the wooden body of the vise hangs off a metal plate mounted on the edge of the bench top in the notch. Of course that foot of the “L” is not intended as a clamping jaw. It won’t come up close to the end of the bench anyway. I was curious about this, too, as I’ve just finished a plan for a bench that has a tail vise.
As to the dog holes, I would image that if the round dog’s jaws were made correctly, they might help to pull the work down to the bench.
-- Until you spread your wings, you'll have no idea how far you can walk.
Betsy
68 days ago
Now that makes sense.
As for making a bench. It’s for sure in my skill level. But not sure it’s in my “desire to make it” mindset.
So to be sure – you would positively get a bench with rectangular dogs.
Thanks for the insight.
68 days ago
I think the rectangular bench dogs make more sense because of there design. But even they vary to some degree.
DaveR
68 days ago
I agree with Jim about the rectangular dogs.
One thing you might consider doing though is drilling some holes in the top for a hold down. You may find one of them useful from time to time.
