Bosch GCM12SD Runout
Forum topic by DJ posted 06-15-2015 07:35 PM 947 views 0 times favorited 6 replies Add to Favorites Watch
View DJ's profile
DJ
3 posts in 1090 days
06-15-2015 07:35 PM
Topic tags/keywords: question miter saw bosch runout tool dial indicator
I recently purchased a Bosch GCM12SD Dual bevel axial glide miter saw. There seems to be quite a bit of run out. I don’t have a dial indicator yet because I don’t know what I need which would be best to test the arbor and the blade. I want something that I can use to check other tools as the need arises. Does anyone have any recommendations for a versatile dial indicator (preferably digital), and attachments to test miter and table saws blade and arbor?
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2362 days
#1 posted 06-15-2015 07:54 PM
Harbor Freight sells one, not digital, but it works. It’s like 10-15 bucks. I’ve used it on my TS and drill press. As for attachments, they sell a magnetic base for it. I’ve just made a jig to hold it where I need it.
View DJ's profile
DJ
#2 posted 06-15-2015 07:57 PM
That’s definitely the right price. Does anyone know any techniques for measuring a miter saw?
View pintodeluxe's profile
pintodeluxe
5652 posts in 2806 days
#3 posted 06-15-2015 07:59 PM
Yeah, that is the trick to determine if the blade or the arbor is at fault. Test them both, perhaps it is just a bent blade.
runswithscissors
2750 posts in 2018 days
#4 posted 06-16-2015 04:05 AM
The magnetic base won’t do you much good on an aluminum miter saw base (though I used to have an old 8 1/4” slider that did have a CI base).
View exelectrician's profile
exelectrician
2327 posts in 2420 days
#5 posted 06-16-2015 04:23 AM
The Harbor Freight magnetic base is quite heavy, you could add a wood clamp to it to gain stability, and yeah, the dial indicator is dead accurate and a bargain at the price.
-- Love thy neighbour as thyself
View DJ's profile
DJ
#6 posted 06-16-2015 05:48 AM
Perfect, thanks everyone!
