I need design help!!!!!
Forum topic by ILLBuilder posted 09-16-2009 11:02 PM 1266 views 0 times favorited 9 replies Add to Favorites Watch
View ILLBuilder's profile
ILLBuilder
5 posts in 3451 days
09-16-2009 11:02 PM
First post here!!!!
I am trying to plan a false faced bookshelf to hide a 10 rifle gun case. I was wondering if any of you old timers have had experience or have any good design ideas for a hinge system I could use. I am planning on using some form of oak hopefully. I have most of the size requirements already thought out but the idea of having an out swinging false face with shelves is racking my brain. Any help or insight would be greatly appreciated. Thanks guys!
9 replies so far
View Kindlingmaker's profile
Kindlingmaker
2658 posts in 3768 days
#1 posted 09-16-2009 11:44 PM
...just had an idea and it most likely won’t work but… What about heavy duty full length slides that concealed on the inside and then the shelf unit could be pulled out 24 plus inches away from the back case for access…
dennis mitchell
3994 posts in 4556 days
#2 posted 09-16-2009 11:54 PM
Is it a built in unit or free standing? Piano hinges would be my guess. Maybe a pivot hinge if it is built in.
View jussdandy's profile
jussdandy
157 posts in 3448 days
#3 posted 09-17-2009 12:42 AM
Ive actully thought about this one b4, for myself but never did it.
Try looking a soss hinges, totally concelled and work good . also look at a rev-a-lock , its a totally concelled latch that is operated by a strong magnet, look at revashelf to see the latch.
-- Randy I have the right to remain silent, just not the ability ; )
View Wingstress's profile
Wingstress
339 posts in 3756 days
#4 posted 09-17-2009 01:28 AM
I seem to remember someone on this site hiding a wine cellar their dinning room that worked really well. Try doing a search for that. (Sorry I’m not more help, but I’ll do a little digging after putting the kids to bed…) Also check Rockler.com hardware just to get some ideas. Something might occur to you…
-- Tom, Simsbury, CT
View interpim's profile
interpim
1170 posts in 3700 days
#5 posted 09-17-2009 01:52 AM
this is a quick drawing I did in sketchup… actually it is pretty horrible, but I just drew it to get my idea across…
Basically build a bookshelf with a sliding cabinet behind it that will slide out to access your weapons. You could put small locking drawers in the bottom to house your ammo, and your rifles can go up top in a rack. Slide it closed and use a push latch to prevent yourself from having to use visible hardware. Maybe put a lock in the top of the bookcase to prevent little hands from discovering the hiding spot.
-- San Diego, CA
ILLBuilder
#6 posted 09-17-2009 07:21 PM
Thanks for all the great ideas fellas! I am much more confident in this project now. I really your idea Interpim. I will do a little more drawing with these new ideas…....hopefully this will be the first thing I post in my projects. Thanks again guys, this place is awesome and full of great advice.
View cFurnitureGuy's profile
cFurnitureGuy
145 posts in 3418 days
#7 posted 09-17-2009 08:12 PM
i agree with Interpim! i have built several things like that in the past… not for guns but similar! heavy duty full extensions drawer slides work great for that concept… there is also other hardware out there for that but it can be expensive!
goood luck!
-- Justin, Savannah,Ga
View huff's profile
huff
2828 posts in 3526 days
#8 posted 09-18-2009 02:22 AM
I’ve done a similar design as Interpim did in his drawing. It works great with HD full extension slides and it’s coming out from the side. (don’t have to worry about tilting).
-- John @ http://www.thehuffordfurnituregroup.com
View CaptainSkully's profile
CaptainSkully
1607 posts in 3800 days
#9 posted 09-18-2009 05:41 PM
I’ve seen a pivoting false front bookcase that had heavy duty hinges on one side, and a caster on the other that rolled across the wood floor. It supported the weight and made the swing easy.
-- You can't control the wind, but you can trim your sails
