Inlay Template?
Forum topic by JJackson posted 71 days ago 365 views 0 times favorited 8 replies Add to Favorites Watch
View JJackson's profile
JJackson
106 posts in 980 days
71 days ago
Hey all,
I have a customer who wants me to inlay the shamrock of Notre Dame into a piece of furniture I am making. I do not own a scroll saw, so I was wondering how one might go about doing this? Anybody have any advise for me?
Thanks,
Jeff
-- Jeff, Indiana
View lew's profile
lew
4496 posts in 652 days
71 days ago
Depending on the size of the Shamrock, you could use a router inlay bushing/bit. The only problem might be getting the piece that will become the “inlay” cut free from the stock. Maybe resawing on a bandsaw?
View Joe Watson's profile
Joe Watson
86 posts in 443 days
71 days ago
i bought a inlay router bit and made a base for mine to make a heart inlay
http://lumberjocks.com/projects/17991
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99552
-- Got Wood?
View navyman's profile
navyman
96 posts in 303 days
71 days ago
On a test board, lay out your pattern and go over it with a sharp knife then use a small router bit and hog out the center ease upto the sides of your pattern not to tought the out line. use a small chislel for that. The hog out should;nt be more than 1/4” deep. then cut out your pattern a little bigger than the hog out a file it to fit. I hope this helps.
-- Michael . USN ( Ret ) Batesville,AR
TopamaxSurvivor
3044 posts in 573 days
71 days ago
When you get to the line, a few degreees of taper on the inlay and the hole it goes into is a lot easier to get a good fit that perfectly perpendicular sides.
View interpim's profile (online now)
interpim
451 posts in 355 days
71 days ago
I cut the inlay for my guitar tuner head with a chisel… it took a while, but I didn’t have a router bit that was smaller than 3/32 wide LOL
-- San Diego, CA US Navy
View Wingstress's profile (online now)
Wingstress
215 posts in 412 days
71 days ago
I’d cut a template out of hardboard with a bandsaw, jigsaw, coping saw, what every you have. Use double sided tape to place the template on your work piece and then use the inlay router bit that Joe Watson recommended up above. Should be pretty easy. Make a couple test cuts on some plywood scraps or something…
-- Tom, Simsbury, CT
View LesB's profile (online now)
LesB
554 posts in 340 days
71 days ago
First it would help to know how large the inlay will be. For smaller ones, say up to 6” or so the router inlay guide bushing method works perfectly. Make your pattern in 1/4” hard board and follow the instructions that come with the bushing kit. Most of the woodworking catalogs have it. Check this one out.
http://www.amazon.com/Freud-FT1500-Inlay-Template-Router/dp/B00004T7NA
-- Les B, Oregon
View brewtang's profile
brewtang
15 posts in 411 days
71 days ago
http://www.woodcraft.com/Family/2001391/2001391.aspx
This is a great set made by Whiteside. You’ll have to cut out the template, to use…but that shouldn’t be too hard using a jig saw, etc.
-- Billy, Jacksonville
