Any suggestions on how to fill or finish these nail holes?
Forum topic by macintosh posted 73 days ago 495 views 0 times favorited 25 replies Add to Favorites Watch
View macintosh's profile
macintosh
4 posts in 89 days
73 days ago
We are currently building a dining room table from reclaimed barn wood. The wood is littered with nail holes, giving it just the right touch of personality and charm. We are not staining the wood, just simply finishing it with an oil-based polyurethane.
Should we fill the nail holes somehow to prevent food or beverage residue from getting into and being trapped in the nail holes? If you think it should be filled, what product would you recommend?
Its quite a challenge- wanting to preserve the wood and protect the nail holes from filling with debris – yet while not wanting to see any evidence that the holes were filled.
I would appreciate your thoughts and expertise. Many thanks,
-the wife
Here’s a sample…
View Sam Yerardi's profile
Sam Yerardi
236 posts in 794 days
73 days ago
I would consider epoxy, dyed or colored to match the hole coloring (assuming you are wanting to retain the black discoloration).
-- Sam
View Kindlingmaker's profile
Kindlingmaker
1477 posts in 425 days
73 days ago
Yup, what Sam said…
View okwoodshop's profile
okwoodshop
159 posts in 74 days
73 days ago
i have been using crushed stone (calcite) and super glue to fill voids in some of my rocking chairs and other projects, add a little copper or brass shavings. the calcite is a soft stone and sands easily. you cant hide em might as well make em pop.
-- Duane,matt_megan@twlakes.net
View woodisit's profile
woodisit
61 posts in 140 days
73 days ago
You might want to go with a cut off rust nail color? To stay in character
-- Woodisit
View roman's profile
roman
1125 posts in 792 days
73 days ago
I put fine grind “pure” pigment, mixing lamp black and burnt umber into either two part auto body filler or just “Spackle” drywall compound.
Its the only “filler” that doesnt fade with time
I prefer the dark colour near black as that is what is stained around the lead nail holes
I might add another tweo cents…...........I use a sharp “V” carving chisel to widen the cracks, then fill them and sand the filler out purposely leaving an “indent” along the crack lines….....seems to add character and warmth
View DaleM's profile (online now)
DaleM
420 posts in 283 days
73 days ago
I would try just taping over or plugging the other side of the hole and flooding the holes and cracks with the same poly you are using for a finish. The first coat of course will soak in some and shrink some as it dries, and will take a couple days to dry but it should seal the wood up well as it dries. A second application (and possibly a third), flooded in to fill the holes again, should mostly fill it, with only a little shrinkage, then you should be able to finish the entire table.
-- Dale Manning, Carthage, NY
View northwoodsman's profile
northwoodsman
100 posts in 645 days
73 days ago
I would leave them exactly the way they are. We have a large, expensive “name brand” table that was built rustic and distressed. It has larger voids and gaps than what yours appears to be. That’s why we purchased it. I think it adds to the character. If you do get crumbs in the holes/gaps just use the hose on your vacuum to clean them out.
-- NorthWoodsMan
View Charles Maxwell's profile
Charles Maxwell
160 posts in 706 days
73 days ago
I would use a clear epoxy. Naturally, you’ll want to try all the ideas above on sacrificial woods before you decide. Good luck. Max
-- Max the "night janitor" at www.hardwoodclocks.com
View Gene Howe's profile
Gene Howe
334 posts in 327 days
73 days ago
My $0.2, epoxy and lamp black.
However, roman’s auto body filler sounds intriguing.
-- Gene
View tblrxdave's profile
tblrxdave
17 posts in 192 days
73 days ago
I’ve made plugs with “real wood” with good results, stained the head to match. I also have a harvest table mabe with reclaimed barn boards that was made back in the early 60’s. The nail holes were left alone. Over time with periodic oiling the holes filled in nicely. Your choice.
Dave
View WibblyPig's profile
WibblyPig
84 posts in 173 days
73 days ago
The first idea that strikes me is old nails with a rusty head. Clinch them from the bottom so they don’t move them finish right over them.
You may also want to consider some mini bowties so those cracks don’t spread.
-- Steve, Webster Groves, MO
View grizzman's profile
grizzman
551 posts in 202 days
73 days ago
everything i make is from reclaimed wood..which means lots of nail holes…depending on the finish look you want…to preserve the reclaimed wood look..leave them alone…..if you dont want the open hole..use apoxy with a black coloring…..and some times i have taken sad dust and grind it down to a very fine dust in a coffee grinder..mix it in with some tightbond lll….....if you do that make sure you leave it high and not flush..as it will dry and give you a depression…..good luck with your solution…...grizzman
-- The Grizzone
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3070 posts in 575 days
73 days ago
I’d vote clear epoxy too. They will crud up with food and dirt if you don’t fill them.
View Julian's profile
Julian
695 posts in 424 days
73 days ago
Another vote for pigment and epoxy. It’s going to last the longest and be the most effective solution out of the others suggested. You need to fill those cracks if you want an easy to clean surface which is important when you have kids.
-- Julian, Park Forest, IL
View Les Hastings's profile
Les Hastings
953 posts in 672 days
73 days ago
Your using reclaimed wood! Why fill them at all? Make them part of the design.
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
View SteveM's profile
SteveM
76 posts in 1066 days
73 days ago
Agree with most other posts. If you decide to fill with something clear, I’ve had luck using thick CA as a plug at the bottom of the hole then filling with 5 min epoxy (the WalMart brand works very well). A quick sand and you are ready for whatever top finish you choose.
View socalwood's profile
socalwood
968 posts in 503 days
73 days ago
We regularly fill all cracks holes etc with wood flour colorants and epoxy . Works well on tables ,floors ,certain wall paneling etc..I am currently testing some other fillers which may have a place in my shop ???? stay tuned -
View MrHudon's profile
MrHudon
26 posts in 109 days
73 days ago
Leave the holes. Use a table cloth when eating so food doesn’t fall in them.
-- Mark, www.mrhudon.com
17127 posts in 476 days
73 days ago
Inlay a Dutchman for that rustic patched look.
View dustyal's profile
dustyal
447 posts in 374 days
73 days ago
hmmm, I think I agree with everyone here… I just did some holes using clear 5 min epoxy with black water color paste mixed in. Surprised me that it worked (water based pigment)... and I liked the result. I tipped some dowel rod into white glue, then jammed in some holes, snapped it off and flushed to the top. That worked okay, too.
Seems like it comes down to personal choice. For a table top… subjected to daily use and food, liquids, etc., I think I would fill with something. Any other piece and I would probably leave ‘em alone…
-- Al H. - small shop, small projects...
View DaneJ's profile
DaneJ
54 posts in 107 days
72 days ago
I kinda like Jims Idea of a dutchman, what about a dovetail dutchman over the hole, straddling the crack to make sure it does not open any more then fill crack with epoxy.
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away...
View GarageWoodworks's profile
GarageWoodworks
210 posts in 522 days
72 days ago
I got one nobody has mentioned yet! :^)
Finish the table first with poly. Fill the hole with paraffin wax by rubbing it into the hole. Wax the entire table with a paste wax. I have done this with small holes and the wax keeps junk out of the hole.
I have not tried with a nail hole, but it should work.
-- Brian http://www.garagewoodworks.com
TopamaxSurvivor
72 days ago
The wax might work for casual tables, but dining table will most likely support hot pans.
View ND2ELK's profile
ND2ELK
6230 posts in 673 days
72 days ago
I have used Fix Wood Patch for years. Comes in many different wood colors, dries hard, sands like wood and takes stain beautifully. Great Stuff! Unifire,Inc. 1-800-745-3282
-- Mc Bridge Cabinets, Iowa
View CanadaJeff's profile
CanadaJeff
167 posts in 508 days
72 days ago
Agreed, grab the epoxy and go to it
