Am I an idiot or what?
Forum topic by kolwdwrkr posted 09-15-2009 03:58 AM 1272 views 0 times favorited 13 replies Add to Favorites Watch
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3789 days
09-15-2009 03:58 AM
Well I complained about my tablesaw and how I couldn’t get it to zero. I was about to get ahold of ridgid and see about cashing in on the warranty. As I cranked on it it was buckling the side of the cabinet and I couldn’t figure out why it wouldn’t go to zero. I figured something was in there keeping it from turning so I cleaned it out and it still wouldn’t work. Today I crawled under there to get a better look. With my hat on backwards and dust falling in my eyes I spyed a small screw. It turns out that it’s an allen screw that can be adjusted from the top!! WTH? Why didn’t I notice that. I’ve seen the screw before and figured it was something that holds the motor mount. Now I know different and feel like an idiot. It’s fixed now, at a perfect 90 degree and lands on 0 so I’m tickled. I can feel happy and stupid at the same time. Let the building continue….. Yippie!!
13 replies so far
View GMman's profile
GMman
3902 posts in 3896 days
#1 posted 09-15-2009 04:01 AM
Are going to make something now!
View Dan'um Style's profile
Dan'um Style
14179 posts in 4182 days
#2 posted 09-15-2009 04:03 AM
chalk it up to experience ! put a check mark beside it and keep plugging away
kolwdwrkr
#3 posted 09-15-2009 04:09 AM
GMman I’m making something now. You can see it on my last topic. I posted pics
GMman
#4 posted 09-15-2009 04:10 AM
Good I was waiting all weekend to see what it was.
117328 posts in 3776 days
#5 posted 09-15-2009 04:11 AM
Hey Keith
We have all been there.
View Tim Dahn's profile
Tim Dahn
1570 posts in 3764 days
#6 posted 09-15-2009 04:15 AM
Welcome to the club Kieth :) Glad it worked out.
kolwdwrkr
#7 posted 09-15-2009 04:22 AM
Oh, btw I did a quick look through of the machine and found that several bolts had vibrated loose. I will check more for sure. SO if you own a ridgid check your bolts frequently. That allen screw had to have vibrated down when I was cutting some angles. I may take that screw out if it’s going to vibrate out. Screws on the mobile base were even loose. Tighten those bolts!!
View MedicKen's profile
MedicKen
1615 posts in 3661 days
#8 posted 09-15-2009 04:36 AM
Maybe a little loctite would be in order?
View degoose's profile
degoose
7244 posts in 3554 days
#9 posted 09-15-2009 04:58 AM
I just pulled my tilting arbor apart to make it to 90 degrees … now it does… make a hell of a difference to the glue ups if you cut square. HEY
View grizzman's profile
grizzman
7836 posts in 3502 days
#10 posted 09-15-2009 04:53 PM
well keith…i will glory with you in your stupidity…sincei put my planer blades in backwards a few months ago…i stillhavent gotten over that one…...i mean sheeesh..that is like takin a shower and not washing your hair first…which i do..and then wash the rest…..its just a matter of dieing brain cells…which the consumption of booze will enhance….maybe we all need a refreshers coarse on wood working procedure…..we can call it woodworkers 202…....well be happy you figured it out and survived…..grizzman
-- GRIZZMAN ...[''''']
Tim Dahn
#11 posted 09-15-2009 11:33 PM
Kieth,
Loctite makes a blue removable type of thread sealant (I use it O.T.J.), this may be a good application. Just a drop is all you need on a screw to prevent it from backing out, but still easy to remove/adjust. Thanks for the heads up, I’ll give my saw the once over tonight.
View cabinetmaster's profile
cabinetmaster
10874 posts in 3757 days
#12 posted 09-16-2009 01:55 AM
Keith, I think we’ve all been there and done that. Sometimes stupidity comes before brains…......LOL
24638 posts in 4050 days
#13 posted 09-16-2009 03:29 AM
Hmmmmmm. Keith, you should’nt ask loaded questions like that one. LOL
