Attaching an overhanging bottom on a box
« back to Hand Tools forum
Forum topic by Pendragon1998 posted 06-13-2015 01:15 AM 2278 views 0 times favorited 4 replies Add to Favorites Watch
View Pendragon1998's profile
Pendragon1998
74 posts in 1815 days
06-13-2015 01:15 AM
I’m an aspiring galoot, trying to learn to do everything using hand tool methods. My next (second) box attempt will be a 16”x10” walnut box. I have a nice walnut board with some pretty grain I want to highlight on the front of the box. The top will perhaps be bubinga, and I’m unsure if I want to use bubinga for the bottom, or just walnut.
I think I’d like to have a slightly overhanging bottom, basically like the one I did on my red oak first box:
However, the bottom of the box in the photo was only about 5-1/2” from front to back, which made me feel comfortable simply gluing the sides onto the bottom. Paul Sellers says his rule of thumb for gluing on a bottom is about 6” max before he worries about wood movement causing problems.
I’d like to attach my bottom on the larger 16”x10” box similarly, but I’m unsure what the best galoot approach is to attaching the bottom. May I have some pointers, please?
Edited to add: I had another question – more of a style-related thought. I was considering doing half blind dovetails on the front and perhaps the back, since I wanted to highlight a sort of attractive grain pattern in the front side board. Would that make it look more like a misplaced cabinet drawer than a ‘jewelry’ box?
View jerryminer's profile
jerryminer
944 posts in 1680 days
#1 posted 06-13-2015 03:34 AM
I see two options:
1) You can attach the bottom with screws in slotted or over-sized holes (no glue), or
2) Make a bottom that “floats” in a groove in the sides—-like a drawer bottom—-leaving a little room for expansion, and make a separate bottom frame to get the “overhang” you want. (If the end-grain bothers you, you can miter the frame).
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#2 posted 06-13-2015 11:43 AM
I would use screws as the previous poster described.
You could do something like sliding dovetails or employ rabbets of some type, but why?
View bondogaposis's profile
bondogaposis
5151 posts in 2590 days
#3 posted 06-13-2015 01:20 PM
I would cheat and make bottom out of plywood fitted in a rabbet then make a base w/ mitered corners to set it on, that could be simply glued on.
-- Bondo Gaposis
View knockknock's profile
knockknock
466 posts in 2412 days
#4 posted 06-13-2015 09:51 PM
... I had another question – more of a style-related thought. I was considering doing half blind dovetails on the front and perhaps the back, since I wanted to highlight a sort of attractive grain pattern in the front side board. Would that make it look more like a misplaced cabinet drawer than a jewelry box?
- Pendragon1998
If you are asking about half blind dovetails on the ends like this box. That is one of the styles of dovetail boxes, because the half blinds can hide the grooves for top and/or bottom panels.
