building a wood stabilizing system
« back to Woodturning forum
Forum topic by cdaniels posted 06-12-2015 04:31 PM 1113 views 0 times favorited 5 replies Add to Favorites Watch
View cdaniels's profile
cdaniels
1320 posts in 1376 days
06-12-2015 04:31 PM
Topic tags/keywords: wood stabilizing vacuum stabilizing burls pen blanks
I understand the whole process of building the system and I have everything priced out. but then I started looking at using a vacuum generator instead of a vacuum pump as it’s 60$ for a 3cfm vac pump and it’s only 10$ for a vac generator that goes up to -80. Since I already have a compressor this could potentially save me a lot of money but has anyone done it this way? Pro’s and cons?
-- Jesus was a carpenter... I'm just saying
5 replies so far
View Nubsnstubs's profile
Nubsnstubs
1223 posts in 1605 days
#1 posted 06-13-2015 12:09 AM
What would be the difference in using a pressure rather than using vacuum? Paint tanks are easy to come by…...... ........... Jerry (in Tucson)
cdaniels
#2 posted 06-13-2015 12:11 AM
because a vacuum generator transforms compressed air into a vacuum inside the valve. it takes the place of using a vacuum pump. and since I already have the compressor than I already have cut out having to buy a vacuum pump. saves money, and space!
cdaniels
#3 posted 06-13-2015 12:13 AM
this is the best definition I have come across
SMC Vacuum Generators use compressed air to generate vacuum using a venturi. Vacuum levels down to -25 inHG (-85kPa) is obtained from single and multi stage units with suction flow greater than 7 SCFM (200 l/min.) SMC’s air vacuum generators can be connected via a manifold or used individually. These compact devices can also be customized to integrate suction filters, vacuum sensor switches, and supply/release valves onto the generator. Additionally, SMC’s generators can be configured to manage distribution of vacuum from a external vacuum source.
Nubsnstubs
#4 posted 06-13-2015 04:27 AM
- cdaniels
My question was not about how a vacuum generator works. It was why not use a pressure tank like a paint pot to cause whatever stabilizing agent you are using to migrate into the wood voids and cavities. Seven cfm can’t be sustained unless you have an industrial 2 stage compressor.
Using a pressure tank, you fill it with whatever pressure you need, close off the valve on the tank, take a nap, and in several hours, release the pressure. Remove the parts and start working on the stuff you just stabilized… Jerry (in Tucson)
cdaniels
#5 posted 06-13-2015 01:42 PM
The design I have uses vacuum pressure. I don’t have experience with it but it seems to be a common agreement that using vacuum instead of a pressure pot works better. Plus a pressure pot costs more
