Smoking drill
Forum topic by socrbent posted 06-12-2015 12:36 AM 969 views 0 times favorited 11 replies Add to Favorites Watch
View socrbent's profile
socrbent
610 posts in 2268 days
06-12-2015 12:36 AM
Topic tags/keywords: drill-driver
A XRP 18v Dewalt hammer drill 4-5 years old that I haven’t used for a couple of months had smoke coming out of the rear vents when it was used in to drill a couple of 1/4” holes in 5/5” particle board. Other than smoke it seems to sound and run OK. Any suggestions?
-- socrbent Ohio
11 replies so far
View Ghidrah's profile
Ghidrah
667 posts in 1221 days
#1 posted 06-12-2015 01:49 AM
I’d open the case and look to see what might have crawled or fell in the vents
-- I meant to do that!
View bbasiaga's profile
bbasiaga
1233 posts in 1994 days
#2 posted 06-12-2015 01:51 AM
Or try and blow th us out wih compressed air. Unless it is eletriacal smoke, which has a pretty distinct smell, I’ guessing it is just dusty.
Brian
View bigblockyeti's profile
bigblockyeti
5120 posts in 1719 days
#3 posted 06-12-2015 02:05 AM
Did the smoke come out as soon as you first started the drill or did it began after the motor was under load and generating heat? I’ve worked on a few of these and the switch along with the wires from the switch to the motor are the weak link. Most of the motors I’ve had to replace are from the cooling fans being busted from dropping them or getting a sheet metal screw or a nail stuck to the permanent magnets and sawing the fan off the armature.
socrbent
#4 posted 06-12-2015 02:07 AM
Smoke was almost immediate.
-- socrbent Ohio
View MarcusM's profile
MarcusM
57 posts in 2979 days
#5 posted 06-12-2015 02:09 AM
Or, if it’s smoking a lot maybe sticking a nicotine patch on it might help. :) JK
Mark
-- Tilbilly Mark
socrbent
#6 posted 06-12-2015 02:11 AM
ha ha – maybe i’ll just get a blanket and send a signal to Dewalt.
-- socrbent Ohio
View Luthierman's profile
Luthierman
221 posts in 1086 days
#7 posted 06-12-2015 02:30 AM
Check your brushes for excessive wear.
-- Jesse, West Lafayette, Indiana
bigblockyeti
#8 posted 06-12-2015 12:18 PM
If the smoke was immediate, it seems more likely that the it is dust related as opposed a function of the motor, wiring or switch overheating. Did the smoke persist or stop after a few seconds? Another thing I’ve seen happen is the carbon from the brushes being smeared between the bars of the commutator effectively shorting the motor. This can sometimes be cleaned, but is done much easier with a motor that can be disassembled.
View JuniorJoiner's profile
JuniorJoiner
486 posts in 3439 days
#9 posted 06-12-2015 12:29 PM
i had the same drill and the same issue, i brought it to a repair shop which told me the fix was more expensive than the drill. as i had found the chuck wearing out on mine anyway, my solution was to replace it with a festool drill.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
socrbent
#10 posted 06-12-2015 01:20 PM
Thanks for the responses. The dirty commutator looks like the cause at this point. The case opened easily. Hope it is as easy to re-assemble. A you-tuber video shows the same model smoking. He cleaned the brushes and commutator and all was well. I’ll clean it this evening and see if that helps.
-- socrbent Ohio
socrbent
#11 posted 06-13-2015 07:19 PM
Opened case, removed brushes and motor, cleaned brushes and commutator area, cleaned between sections on commutator, used thin strips of 400 grit sandpaper to clean surface of commutator, reassembled and it seems to work with no smoke.
-- socrbent Ohio
