| Forum topic by noblevfd | posted 75 days ago | 351 views | 0 times favorited | 8 replies | ![]() |
75 days ago |
75 days ago |
screw on plastic feet -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
75 days ago |
I’ll second Jim. We used the nail in kind but same idea. We had them on the chairs for 10 years with our boys dragging the chairs in and out from the dinner table. Never did leave a mark. |
75 days ago |
I use UHMW and use countersunk screws to attach them. I had a 12” x 96” piece left over from a workbench top and started using it on chair and table legs. Works great, easy to cut and slides easily…leaves absolutely no marks -- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little |
74 days ago |
I used to have carpet throughout my first floor then replaced it with hardwood. I never realized how many pieces of furniture I had that would scratch the wood. Chairs are particularly bad because they move a lot. First you have to sand the leg bottoms flat. It can take a little trial and error. Then at Lowe’s or Home Depot you can buy fabric pads that are self sticking. I used to have plastic feet but there isn’t a plastic soft enough to not scratch and stand up to wear and tear. One day the plastic will wear through and suddenly you have a screw or nail sliding along the floor. IMHO |
74 days ago |
i use flet pads on mine works a treat Andy -- cut it saw it scrap it |
74 days ago |
I think the nail on or screw on nylon feet work the best. If you dont move the furniture a lot, like a sofa, you can put the cups under the feet. They come in various sizes. -- Wayne - Plymouth MN |
74 days ago |
I dont have carpet anywhere in the house and I use both nylon and felt, and they do an equal job, I think the important things are a surface that is smooth and nonabrasive and make sure that they stay that way this includes the fastner, nail or screw is critical… I thnk the real key is to keep things off the floor that get inbetween the floor and chair. I tracked some leaves in last fall and they got between the nylon foot of a dining room chair and left a mark, I guess if crud built up on a felt foot it would do the same. I know this may not be PC, but here goes anyway… make sure that the housekeeper knows to keep the funiture feet clean as well as the floor ;) -- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... |
74 days ago |
thanks for all the responses I’m going to try the nylon and good tip danej to keep the feet clean also thanks noblevfd God Bless |
| Forum | Topics |
Woodworking Skill Share
2924 |
3956 |
257 |
954 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2397 |
LumberJocks.com Site Feedback
524 |
