Waterbased Poly, What am I doing wrong?
Forum topic by ric53 posted 06-10-2015 12:30 AM 754 views 0 times favorited 4 replies Add to Favorites Watch
View ric53's profile
ric53
194 posts in 1488 days
06-10-2015 12:30 AM
I normally use Velvet Oil and top it with several coats of wipe on poly but when I want to retain as much of a white color as possible I’ll use a water based poly. The problem is, no mater what I use to apply it with I can’t get it to flatten out. I either get brush strokes or streaking if I use a foam applicator. I am careful not to over brush and I have used just about every brush out there to eliminate the strokes. I am wondering if anybody has any suggestions on how to solve this issue. The next time I do this I think I might use a thinned shellac. If I go that route can I thin the shellac and wipe on as with the oil based wipe on’s? Thanks for any suggestions you may have.
-- Ric, Mazomanie
View Ross's profile
Ross
142 posts in 1941 days
#1 posted 06-10-2015 02:11 AM
Try applying the finish with a boars hair brush. To eliminate brush strokes hold the brush at 90 degrees (straight up and down) With just the tip of the brush touching the work piece.
-- "Man Plans and God Laughs"
View ChuckC's profile
ChuckC
828 posts in 2904 days
#2 posted 06-10-2015 02:29 AM
For waterborne polyurethane you have to use a synthetic brush. Keep the brush wet as you work. Also consider spraying it. I’ve had good luck using rattle can Minwax.
Good luck!
View Daruc's profile
Daruc
460 posts in 1101 days
#3 posted 06-10-2015 02:49 AM
I never get brush strokes when I spray, just sayin. No help at all for brushing, sorry
View gfadvm's profile
gfadvm
14940 posts in 2659 days
#4 posted 06-10-2015 02:50 AM
The answer to your shellac question is yes: I cut Zinsser Bullseye Shellac 1:1 and wipe/rub it on. It dries almost instantly. Don’t try to lay on a thick coat. Black Cherry has a good blog on rubbing on shellac that has worked very well for me.
