Black & Decker Plunge Router Problem
Forum topic by BlueLight posted 09-12-2009 10:59 PM 867 views 0 times favorited 5 replies Add to Favorites Watch
View BlueLight's profile
BlueLight
3 posts in 3206 days
09-12-2009 10:59 PM
Topic tags/keywords: router question
I got a bit stuck in the router but got it out .. now I can’t get any to go back in. I have cleaned and lubed the collet and still no luck … any thoughts ???
5 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3588 days
#1 posted 09-13-2009 12:53 AM
I’ve never had that problem and I don’t have a B&D, but here is an idea.
Take the collet off the router and mount it in a vise across the “hex” nut.
Then take the shank end of a 1/2” drill (or use a 1/2” drill rod and see if you can put it through the colle t from the bottom side of the collet. This might spread the fingers out so you can then put the bits in normally.
-- Joe
117126 posts in 3605 days
#2 posted 09-13-2009 01:39 AM
Joe’s approach is good for a really stuck bit but some times you can just hit the the bit sides ways with a piece of wood will loosen it.
BlueLight
#3 posted 09-13-2009 02:43 AM
There is currently no bit in the collet. Are you saying that it is stuck in a ‘closed’ position somehow? I can try that w/o a bit in it, but carefully so as not to damage the threads
View GMman's profile
GMman
3902 posts in 3725 days
#4 posted 09-13-2009 03:37 AM
I have a B&D router and the collet always hold the bit, which is why it’s on the shelf for the last 3 years.
BlueLight
#5 posted 09-13-2009 02:20 PM
I was doing some research and I see that this unit has been discontinued. i wonder if this is part of the reason…....
