HVLP spray guns
Forum topic by RetiredCoastie posted 09-12-2009 05:30 PM 5558 views 1 time favorited 10 replies Add to Favorites Watch
View RetiredCoastie's profile
999 posts in 3115 days
09-12-2009 05:30 PM
Topic tags/keywords: question
Can anyone recommend a good quality HVLP rig for under $200.00 and do they produce even finishes?
-- Proud Supporter of Homes For Our Troops
10 replies so far
View bruc101's profile
1197 posts in 3474 days
#1 posted 09-12-2009 05:48 PM
Have a woodworking friend that has this $79.95 set. He painted in aerospace for a living until he retired. He bought this set and his furniture finishes are flawless. Like he told me, 10% in the gun and 90% in the know how of spraying finishes and making the gun work for you.
-- Bruce Free Plans
117029 posts in 3509 days
#2 posted 09-13-2009 03:38 AM
the under $200 is the hard part
-- wood crafting & classes
View thiel's profile
381 posts in 3224 days
#3 posted 09-13-2009 04:19 AM
Earlex has a rig for $139ish I think.
-- Laziness minus Apathy equals Efficiency
View 45acpbuilder's profile
49 posts in 3145 days
#4 posted 09-13-2009 10:36 AM
I would recommend the Sharpe Finex Mini HVLP gun. I use three in my powder/industrial coating business and they’re the best value going. They’re available at any good automotive paint supply store and cost around $75.00. Replacement parts are cheap and the ones I have have been used every day for over two years. I’ve never had a problem with any of them and they give an excellent pattern. We do transparent ceramic hard-surface coatings for anti-graffiti work and the gun we use for that is two years old and still working perfectly.
-- M1911BLDR
View DaneJ's profile
56 posts in 3140 days
#5 posted 09-13-2009 11:45 PM
Coastie… if you already have a compressor you may want to try a “conversion” gun. I have a few Devilbiss and Iwata guns, the Iwata is out of your price range, you may find a used Devilbiss Plus in your price range.
For about $130 you can get a Devilbiss Finishline 3 kit with the disposable cups at
I have found the disposable cups well worth it, they allow you to spray at any angle, including upside down! also when spraying WB finishes with the disposable cups I will leave the finish in the gun for an hour or so between coats without any problems because the gun sucks out all of the air!
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... Tom Waits
#6 posted 09-14-2009 05:43 AM
Thanks all for your input. I do have a compressor but was hopeful that I could get a turbine unit to get away from the noise. Maybe Santa will bring me a system if I’m good. Thanks all!
#7 posted 09-15-2009 01:06 AM
I don’t know if a turbine is that much quieter, and Most of the units I have used or seen have a fairly short hose so you wont get far either. Turbines are definitely more portable…
If you don’t need portability I would go with a good conversion/hybrid gun and use the $$s you save on accessories like a spray-booth quality filter and portable spray booth stuff.
if you have a FWW account check out Michael Dresdner’s introduction video on spraying it is a very good overview…
View ,'s profile
2387 posts in 3479 days
#8 posted 09-15-2009 03:00 PM
Personally from my experience I have just loved using a small kobalt hvlp gun I buy from lowes. I get excellent results. It is such an easy gun to use and feels light as a feather. I have 3 adjustments, spray patter adjust, fluid adjustment, needle adjustment and I added a gauge with air pressure adjustment. The only thing is I cannot select any other size needles but so far I have sprayed everything, stain, oil and latex paint, lacquers… The best part, it only cost 37.00 at Lowes. You would think it is low quality with that price but I will say the quality is very good. One guy says 10% gun, 90% technique. Either my technique is getting better or the gun helped because I have recently sprayed some great lacquer finishes with this gun. I also have experience with earlex, capspray, and a husky gun (somewhat limited) but I just love the kobalt gun.
View hvlp's profile
1 post in 3095 days
#9 posted 09-27-2009 02:40 PM
Check out this website, they sell some HVLP Spray Guns
They have one for under $200 and a couple just over, you can call them to see what they have in stock.They always have more then what you see on their website
hvlp spray guns
#10 posted 09-27-2009 04:42 PM
Thanks for the link I will check it out.
