My new drop box
Forum topic by b67mack posted 06-08-2015 05:11 PM 1015 views 1 time favorited 13 replies Add to Favorites Watch
View b67mack's profile
b67mack
60 posts in 1442 days
06-08-2015 05:11 PM
The drop box I installed to catch the big chunks before they hit my DC keeps filling up and plugging the line.
Am I missing something here – shouldn’t most of the material keep passing thru and just the large heavy stuff “drop out” ???
13 replies so far
View bondogaposis's profile
bondogaposis
4755 posts in 2374 days
#1 posted 06-08-2015 05:30 PM
A picture would help. Sounds like you built a separator.
-- Bondo Gaposis
b67mack
#2 posted 06-08-2015 05:41 PM
didn’t intend it to be a separator!!!
I wanted a horizontal drop out
I used an old ice chest I had because it didn’t need any further sealing = apply the Dc and the lid will not come off
I placed two 4 inch connectors on one side – because that side was relatively flat
I ASSumed the material would swirl in and back out in a 180 degree arc leaving the destructive bits in the box
I added a baffle in the middle of the ice chest as an attempt to make the material pass under the baffel and keep the box clear – that failed immediately
and in that I cannot possible remove the lid unless the DC has completely stopped – I think Ill try to “allow” some extra air into the box to promote swirl
but if anyone has another idea please help me
Kind Regards
B
View HerbC's profile (online now)
HerbC
1763 posts in 2882 days
#3 posted 06-08-2015 05:48 PM
There’s the major problem. The airstream may do a 180 but most of the debris will not make the curve.
Put the inlet on one end of the box and the outlet on the other end. Try it without a baffle. If it doesn’t drop enough, put a 45 degree elbow on the inside outlet connection…
HTH
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
b67mack
#4 posted 06-08-2015 05:50 PM
I have also been dreaming that maybe some sort of “agitator” such as a piece of a snow blower on a 1 RPM motor might keep the box clear
still thinking up stuff to make this work
b67mack
#5 posted 06-08-2015 08:07 PM
Thank- you
i will move the connections tonight and try again after the glue sets up
I was concerned that the big pieces would have enough momentum to pass thru the drop box if I had a straight line
View timbertailor's profile
timbertailor
1594 posts in 1447 days
#6 posted 06-09-2015 01:32 PM
I would do some homework on a Thein Cyclone.
b67mack
#7 posted 06-09-2015 03:11 PM
Thank- you for the comment – yes I have done my homework on the thingy and thats why I am trying to build a DROP BOX
Please understand – I don’t want the drama of having to open the thingy container every two minutes to see if maybe its full or not
I simply want a drop box that doesn’t plug up with fines – yet works well enough to sort out the destructive bits before they hit the fan
Doesn’t anyone make a tested and proven device like this ? [ that doesn’t cost more than the DC did ]
View AZWoody's profile
AZWoody
1346 posts in 1246 days
#8 posted 06-09-2015 03:45 PM
I don’t understand what the difference is between a drop box and a separator?
If it does what you want to do, it will take out the largest of the objects and let the finer parts go to the dust collector.
The largest pieces are going to be larger in size, so will fill up your separator faster than whatever you have to collect the dust on the dust collector.
It seems to me you need to make something a little larger but you don’t say what size dust collector you’re using. The higher the hp and cfm, the larger your box is going to be.
View ClammyBallz's profile
ClammyBallz
435 posts in 1159 days
#9 posted 06-09-2015 03:50 PM
You can put a window on a separator. Cut out a square in the container, heat up some thin acrylic with a heat gun, form it to the shape of the container, use some rubber material such as pond liner to make a gaskets and screw it on the container. Should look like this.
4998 posts in 2516 days
#10 posted 06-09-2015 04:47 PM
With a cyclone, any small leak in the dust bin will allow the fine dust through to the filter. I imagine the same principal would do what you want, it will also reduce air flow at the tool.
View JoeinGa's profile
JoeinGa
7736 posts in 2030 days
#11 posted 06-09-2015 05:11 PM
You can put a window in the catcher as Clammy says. Here’s how I did it .
http://lumberjocks.com/topics/74481
b67mack
#12 posted 06-09-2015 08:08 PM
- Fred Hargis
That gives me an idea
I am going to place a pipe to atmosphere =opposite and inline with the suction port – of the drop box.
Ill valve it and direct it with a stub – to allow a variable “leak” that might be the Voo DOO to keep that port clear
View gfadvm's profile
gfadvm
14940 posts in 2713 days
#13 posted 06-10-2015 12:49 AM
Click for details
This was my answer to your dilemma. Still working like it should.
