| Forum topic by ryno101 | posted 78 days ago | 250 views | 0 times favorited | 10 replies | ![]() |
78 days ago |
Topic tags/keywords: question joining I’m in the middle of building my workbench, and have come up short on one piece… This is the design for my base assembly, it’s all 4×4 mahogany:
The problem is that I don’t have a single piece for the top section of one of the leg assemblies… I mis-judged my cuts (learning!) and would very much like to avoid going out an purchasing another 10 or 12 foot piece of mahogany! What I have is three pieces, 11 3/4”, 13 7/8” and 9 1/4” long that I want to join together to make the top piece. My thought was to do something like this:
What do you think? Is the mortise too close to the joint? Is this the strongest way to do this? Keep in mind that the pieces in the above pic are rotated 180 degrees to show the location of the mortises, they’ll actually be on the bottom of the piece, fitting into the tenons on the tops of the legs. -- Ryno |
78 days ago |
glad to see you’re busy Ryan, hows the new saw? my first instinct on this one is – don’t do it. just looks too much of a hassle. I would prob try and find a piece that would work for this as a 1 piece. If you want to stop by and look through my lumber – maybe you’ll find something good enough (I can’t tell what would fit the color/hardness of what you’re using). another option is to use a different specie (maple? I have a feeling you’ve got some of that…lol) and veneer it with the mahogany to keep the color consistency – although – honestly – this piece is under the top and might not even show. -- When in doubt - There is no doubt - Go the safer route. |
78 days ago |
With Purplev’s advise maybe replace both sides so they will match. I you want to continue then possibly a lap joint and doweled from the back side… I think this would give the greatest amount of long grain surface for gluing and there would only be vertical joints. ...finger joints would be even better. -- Never board, always knotty, lots of growth rings |
78 days ago |
Sharon, New saw is AWESOME! Can’t tell you how much of a difference a proper saw makes! (but you knew that, didn’t you!) I was wavering between swapping out another piece as well, but without a planer, getting the dimensions right is going to be very difficult. The only thing I have “in stock” that I could dimension with my table saw is 5×5 white cedar left over from our new fence, and it’s at the opposite end of the spectrum from the mahogany in terms of hardness and heft. I’m reluctant to use that if I can avoid it, and everything else I have would need to be done as a glue-up. I’m not all that concerned about matching, as you noted this is going to be under the top, and will be hidden by the skirt I’m planning on wrapping around the top. I see the effort involved in cutting these joints as a learning experience anyway. The mortises and tenons I’ve cut for this project are the first I’ve ever done, and I’m happy to have some more practice on a more challenging joint like this one. -- Ryno |
78 days ago |
I wouldn’t be concerned about the difficulty of making that joint – on the contrary – I would suggest you do it – but on a different project. for reason is because the purpose of this part is to keep the top from cupping, and with 2 extra joints under the top across it’s width you are introducing another 2 weak spots where you have inconsistency with the grains – which might result in inconsistent movements between the sub-pieces which might result in strange forces applied to your top that can take it off flat – as you recall it is only held with nails, and there is a tendency in the material to rock and roll. you are welcome to use my planer if you need it. however – I think the cedar choice may be too soft and brittle for this application. I have some 4×4 (3.5×3.5) leftover Douglas FIR if you want them – I originally planned to use them for a base similar to yours, but ended up not using them – it’s all yours if you want it. -- When in doubt - There is no doubt - Go the safer route. |
78 days ago |
Wood is like a mountain os snow…...if you down hill ski, the mountain will humble you and so will wood. When you pay for your own mistakes your learning curve increases exponentially. Suck up your pride, cry and get another chunk of wood…..........I’m betting you wont make the same error twice! |
78 days ago |
My first choice for this would be to take Sharon up on his offers. Can’t get much better than that. Too bad he lives so far away from me. Second, if you absolutely have to use what you’ve got, perhaps you could rip it into pieces such that you can glue it up sort of like a brick wall. A few years ago I built a big cabinet for my shop. The frame is all made of 2x lumber scraps saved from various projects. For a couple of pieces, I ended up ripping and gluing to get the length. One of the pieces needed a slot in it for a pull out tray and this method resulted in less waste. -- Until you spread your wings, you'll have no idea how far you can walk. |
78 days ago |
Definately the “brick wall” approach as suggested by DaveR. It would result in a structurally sound and stable piece. -- Don, Pittsburgh |
78 days ago |
I have to go along with Kindlingmaker on the leg. -- Remember--- one good turn-- gets most of the blanket!!!! |
78 days ago |
I agree with Sharon I would use anything that is one piece and not the three section glue up as shown in your sketch . laminating length wise is fine . -- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com |
78 days ago |
If you insist on using the 3 pieces, I think I would dovetail the white faces in yoiu sketch. -- Debt is nothing more than the 21st Century's form of slavery. |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
