Compressor abuse, why not?
Forum topic by CB_Cohick posted 06-05-2015 02:31 PM 1002 views 0 times favorited 8 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
486 posts in 1280 days
06-05-2015 02:31 PM
Topic tags/keywords: question compressor maintenance
I recently acquired a Bostitch pancake compressor, nothing fancy, and not the compressor I want. But, it was the best option available at the time. I understand that standard practice is to drain the tank at the end of the day and empty any condensation that has collected to prevent rust and extend the life of the tank. However, bearing in mind I don’t particularly like this compressor and would gladly sell it in its current barely used state for half price, why not leave the tank charged and ready to go instead of constantly draining and filling? Other than condensation in the tank, what else is wrong with leaving it charged?
-- Chris - Would work, but I'm too busy reading about woodwork.
8 replies so far
View whope's profile
whope
142 posts in 2474 days
#1 posted 06-05-2015 02:45 PM
Depends on how often you use it I guess. I use my compressor sporadically. If I used it everyday, I’d leave it charged. I might vent it at the end of the day a little just to purge any moitsure from the day. A second or two at most. If your compressor is like mine, the vent really isn’t on the bottom, so unless I tip it, all the moisture wouldn’t be purged.
Of course you could throw caution to the wind and hope for an excuse to upgrade…
-- Measure it with a micrometer, mark it with chalk, cut it with an axe.
View johnstoneb's profile
johnstoneb
2944 posts in 2202 days
#2 posted 06-05-2015 03:08 PM
You don’t need to drain the tank completely of air all you need do is open the drain valve briefly and vent the moisture that condensed during the day.
-- Bruce, Boise, ID
View Tenfingers58's profile
Tenfingers58
96 posts in 2707 days
#3 posted 06-05-2015 03:54 PM
I vent the tank to loose the moisture, then shut off the breaker in case a leak develops.
CB_Cohick
#4 posted 06-05-2015 04:05 PM
- Tenfingers58
I like this idea. The compressor I am abusing has an on-off switch .
MrUnix
6771 posts in 2228 days
#5 posted 06-05-2015 04:12 PM
I have a 40 gallon Craftaman badged DeVilbiss compressor out in the garage that I plugged in and turned on something like 14 years ago. Only time it’s been off is when we have a power failure. I try to remember to drain the tank at least once a year, but even that doesn’t always happen.
View jerryminer's profile
jerryminer
930 posts in 1470 days
#6 posted 06-05-2015 06:49 PM
Other than condensation in the tank, what else is wrong with leaving it charged? – CB_Cohick
Moisture in the line will get into your tools, so accelerated deterioration there, in theory.
If the power stays on, and the tank rusts out, you could have an exploding compressor.
View pintodeluxe's profile (online now)
pintodeluxe
5706 posts in 2842 days
#7 posted 06-05-2015 06:57 PM
I drain the tank after every use, and it lasted 26 years. It finally rusted out despite my efforts, but I’d say 26 years is a pretty good run. If you spray finishes such as lacquer, shellac, or poly you will want to drain the tank regularly as well as use a good water trap.
View Underdog's profile
Underdog
1118 posts in 2065 days
#8 posted 06-05-2015 07:08 PM
You can always get an autodrain… but that might be more than the compressor is worth.
