cellulose sanding sealer mix
« back to Woodturning forum
Forum topic by 3285jeff posted 06-05-2015 11:28 AM 2131 views 0 times favorited 4 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
159 posts in 1891 days
06-05-2015 11:28 AM
I have been watching mike waldt videos on you tube and he uses a cellulose sanding sealer mix using cellulose sanding sealer and cellulose thinners,,actually his brand name is chestnut,,the product that is,,and I have tried to find this,,but the only results I have as far as buying it are in the uk,,can anyone give me some info on finding this in the united states,,,or something they recommend that is just as good,,thank you
View TheDane's profile
TheDane
5534 posts in 3836 days
#1 posted 06-05-2015 12:50 PM
Cellulose is nitrocellulose which is lacquer. Look for Deft lacquer at your local BORG or hardware store.
3285jeff
#2 posted 06-05-2015 02:17 PM
What do you cut it with and the ratio,,,,mike waldt says 3to1
TheDane
#3 posted 06-05-2015 03:30 PM
There is no right or wrong … it is up to you and what you think works best for you.
I cut mine 50/50 … that’s what Cap’n Eddie recommends.
View HerbC's profile
HerbC
1790 posts in 3032 days
#4 posted 06-05-2015 03:33 PM
Cut with lacquer thinner… You may need to add lacquer retarder if you get any blushing.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
