white crusty bubbles in shellac/poly help the newbie
Forum topic by droppedtuning posted 06-04-2015 05:55 PM 1052 views 0 times favorited 14 replies Add to Favorites Watch
View droppedtuning's profile
droppedtuning
31 posts in 1675 days
06-04-2015 05:55 PM
please help the newbie. building a fireplace mantle from pine. the whole surface was scrub planed for texture , then grained was raised then knocked down. i sprayed transtint waterbased dye on it. let it dry a day then two coats of bullseye dewaxed sealer on top of that. i scuff sanded after each coat had dried a day. yesterday i did one coat of 50/50 minwax oil poly and mineral spirits . today i have a white crusty disaster. i know moisture will turn poly white at times although this was thinned half down and wiped off single coat but bubbles and crusty rough ? please help the newbie ? thanks guys !https://s3.amazonaws.com/vs-lumberjocks.com/npflrms.jpg!
14 replies so far
17242 posts in 1731 days
#1 posted 06-04-2015 05:57 PM
Exactly which poly did you use?
View hotbyte's profile
hotbyte
989 posts in 2850 days
#2 posted 06-04-2015 05:58 PM
Weird. Did you shake the poly vs stirring? I’ve always heard to never shake it or it will get air bubbles. So, I never have. I don’t know if that is what the air bubbles would look like.
droppedtuning
#3 posted 06-04-2015 06:01 PM
stirred not shaken
View bobasaurus's profile
bobasaurus
3363 posts in 3059 days
#4 posted 06-04-2015 08:03 PM
It must be the mixing of finish bases, though the shellac should have helped. Was the shellac dewaxed? If not the poly won’t stick on top of it. Try sticking to all water based, or all oil based dyes/sealers/finishes.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View chrisstef's profile
chrisstef
17109 posts in 2881 days
#5 posted 06-04-2015 08:19 PM
I think you’ve got moisture trapped under the poly film. Maybe the mineral spirits weren’t mixed well enough in with the poly and in some spots there was more spirits than poly and it never got enough time to evaporate fully. I doubt it was the shellac. Id sand it back and go full strength with the poly, possibly a new can.
Was it the fast dry poly?
View MrUnix's profile
MrUnix
6199 posts in 2074 days
#6 posted 06-04-2015 08:19 PM
Lots of different solvents used there… so it’s got to be a bad interaction. The dye is alcohol/glycol based with water. The sealer is ethanol based, and the poly was mineral spirits. A finish like you got usually results from not letting the lower coats of whatever flash off the solvents, and mixing/matching like that usually requires making sure that they are completely dry and all the off-gassing is done. Bummer, but you will need to take it back down to bare wood and try again… perhaps waiting a bit longer between steps if you choose to go the same route.
4829 posts in 2368 days
#7 posted 06-04-2015 08:45 PM
It’s not obvious to me what caused that, certainly nothing in the schedule you followed seems wrong. Let me ask about the mineral spirits, it wasn’t one of the new “green” formulas, was it? As much as I dislike Minwax anything and would like to blame the oil based varnish, I don’t think it would have done that.
#8 posted 06-04-2015 08:59 PM
It wasn’t the oil modified poly was it? I don’t think that would be miscible with mineral spirits.
droppedtuning
#9 posted 06-04-2015 09:34 PM
i followed transtints website directions. i wiped mineral spirits over it and nothing. dewaxed shellac yes
droppedtuning
#10 posted 06-04-2015 09:36 PM
View Bill White's profile
Bill White
4823 posts in 3835 days
#11 posted 06-04-2015 10:04 PM
Was the wood dry, prepped in the sun?
I’ve seen and experienced that effect from using or drying outside on a sunny day.
Bill
-- bill@magraphics.us
View gfadvm's profile
gfadvm
14940 posts in 2565 days
#12 posted 06-05-2015 12:29 AM
Like Bill, I have had this happen when I thought putting it out in the sun to speed drying was a good idea. NOT! Other than that, I have no idea why it happened.
droppedtuning
#13 posted 06-05-2015 03:38 AM
i gave up and hit it with stripper and alcohol. now i have to figure out what to do with the dye
chrisstef
#14 posted 06-07-2015 08:49 PM
Dont thin the poly and i bet youll be all right with your original finush schedule. There’s a drying agent as well as flatteners in the satin fast dry poly. Id bet theyre all acting against each other when you introduced more mineral spirits to the equation.
