Powermatic PM3000 and dado specs
Forum topic by psient posted 06-03-2015 07:26 PM 1083 views 0 times favorited 15 replies Add to Favorites Watch
View psient's profile
psient
82 posts in 2185 days
06-03-2015 07:26 PM
I have a new Powermatic PM3000 and a shop! I have a question for anyone with experience using this machine. It specs for a limit on dado diameter @ 8 inches. Talked to their tech support and they don’t know why this spec is listed with the machine.
Anyone ever use a 12” or 10” dado with it. I already have the dado set and can’t imagine it not working on this table saw.
Please let me know.
Thanks
Psient
15 replies so far
View knotheadswoodshed's profile
knotheadswoodshed
211 posts in 2044 days
#1 posted 06-03-2015 07:30 PM
what set do you have?
I can’t really picture a use for anything larger than an 8” set for most home/hobby users.
anything bigger is really slinging a lot of metal.
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
4825 posts in 2364 days
#2 posted 06-03-2015 07:50 PM
Well, the new ones seem to be 7.5 HP. 14” saws….think that’s enough??? ;)
Hard to imagine (if that’s the one you have, I think earlier models came in 5 HP versions) it wouldn’t handle a 10” dado. I’d try it and see…a little common sense here goes a long way. Mount it, spin it by hand, then power it up. For them to spec a 8” set max for that saw had be a brain fart on someone’s part.
View BroncoBrian's profile
BroncoBrian
436 posts in 1830 days
#3 posted 06-04-2015 02:23 AM
Why would you use larger than an 8” stack? Isn’t that pretty standard even for 3 and 5HP saws?
-- Bigfoot tries to take pictures of me
View MrUnix's profile
MrUnix
6188 posts in 2070 days
#4 posted 06-04-2015 03:43 AM
If it says 8”, I’d take them at their word on it… I doubt some poor slob at the end of the telephone could tell you why through – they aren’t the ones who engineered the thing (and those are the only guys who could answer that question).
It does seem odd that a high horsepower 1” arbor machine couldn’t handle more though. But as Randy points out, that is a lot of mass to be slinging around. Maybe try to get your question asked further up the food chain at Powermatic and see if they can provide a reasonable answer.
#5 posted 06-04-2015 11:51 AM
I kept thinking about this and wonder if it’s a matter of the insert. If the insert opening is only large enough to let an 8” set be raised all the way…..please, I understand no ones cuts that way; but on my Unisaw the opening in the dado insert seemed to be sized to an 8” set. It may have been able to handle a 10” set, but it could have cut into the insert (I think, I sold that saw).
psient
#6 posted 06-10-2015 06:58 PM
Here’s the correct spec on dado size for my table saw . . . From Powermatic:
The dado is 12”.
Regards,
Gary Bellinger
Tech. Service Representative
Direct (800) 274-6846 X 1321
gbellinger@jpwindustries.com
JPW Industries
427 New Sanford Rd.
Lavergne,TN 37086
Phone (800)274-6846
www.jpwindustries.com
#7 posted 06-10-2015 07:11 PM
Oh, baby….that sucker is going to be expensive. Glad they got you the correct info.
psient
#8 posted 06-11-2015 05:57 PM
- Fred Hargis
I already have the set. I haven’t used it as I just recently made a shop for myself. I need to make a sacrificial fence but haven’t decided on the actual design. At first it was gonna be hdpe but now I’m thinking just scrap. Maybe some doug fir I have laying around. The cut depth possible with the PM is over 4 inches.
View SirIrb's profile
SirIrb
1239 posts in 1102 days
#9 posted 06-11-2015 06:08 PM
Side Note:
I lust after your saw.
50 shades of Gold.
Thats all.
psient
#10 posted 06-12-2015 12:34 PM
Side Note:
50 shades of Gold.
Thats all.
- SirIrb
Thanks for the response.
It’s quite powerful but still characteristically accurate. Very large blade(s). Needs 3 phase power so I have a rotary phase converter.
It’s really good for working with construction-sized lumber rather than cabinetry in particular. So working with beams is possible due to the depth of cut. Anyway that’s the theory.
SirIrb
#11 posted 06-12-2015 02:49 PM
I am vary familiar with the PM 72 (green) and the 3k seems to be the new gen of it. We had that beast (12”- 14”, if I remember correct it would swing up to a 14”) hooked up with a 4 wheel powerfeeder. It would throw some serious chips. Watched my boss take the tip of his thumb off on it. Believe it or not the saw didnt even bog down on that. He didnt loose a digit or even part. Just the tip.
Side Note:
50 shades of Gold.
Thats all.
- SirIrb
It s quite powerful but still characteristically accurate. Very large blade(s). Needs 3 phase power so I have a rotary phase converter.
It s really good for working with construction-sized lumber rather than cabinetry in particular. So working with beams is possible due to the depth of cut. Anyway that s the theory.
- psient
psient
#12 posted 06-13-2015 05:20 PM
So I tried to set up my Forrest Dado king 12244 12” dado. I cannot mount it as the saw arbor is not long enough. I will have to re-contact Powermatic to find out why the saw won’t accommodate this cutter. This makes no sense to me as I thought many people owned this saw. However, when it comes to using a dado it appears not-so-much.
The stack will attach without the outside blade washer with the arbor nut just reaching the end of the threads so that the arbor is flush with the nut face. I’d like to understand why this saw won’t accept the dado.
MrUnix
#13 posted 06-13-2015 05:49 PM
I notice that the specifications for that saw on the Powermatic web site now says it will take up to a 12” dado stack :) But it also says it can only do up to 13/16” wide… that Forrest can go up to 29/32” wide, so you won’t be able to do the full stack. Not sure I’m seeing what the problem is, other than you are trying to exceed the max dado width… am I missing something?
#14 posted 06-13-2015 06:08 PM
It sounds to me like you’re OK. You don’t need the outside washer, and if the arbor nut is fully engaged you should be good to go. Pay attention to the width as Brad pointed out, it may be you have to back off one chipper…but it sounds like you’ve got it.
psient
#15 posted 06-13-2015 07:05 PM
OK I just figured out the problem I was having. It was not clear to me that the outer washer was unnecessary. I am glad you guys affirmed this conclusion independently.
I’ll reinstall the dado set w/o the washer. Previously I noticed that if I did not use the washer the entire set seemed to fit with the nut fully engaged. However, I did not try it out. This time I will.
Why the washer is not needed seems counter intuitive as the inertia must be greater using a dado than a single blade. I had to keep searching until I found several videos of guys mounting their dados and noticed no one was using the washer.
I wonder why no one mentions it and there was no mention in the literature either. It seems reasonable that someone who has never used a dado set before would NOT guess that the washer isn’t needed. Like I said, there is no mention of this commonly made. In my case, finding out the washer can be disregarded was not a study in quick access so much as it was one of careful observations.
Thanks for the help you guys. I’ll try to set it up.
Now I have to make an insert. I don’t have any baltic birch plywood. The plywood I do have has voids. I also don’t have a band saw or a sanding disc. I can clamp my belt sander to the table after shaping the insert with a jig saw.
Thanks again
