Center Workbench Assistance.
Forum topic by Blackie_ posted 06-03-2015 06:18 PM 1668 views 0 times favorited 17 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2750 days
06-03-2015 06:18 PM
I’m in the starting phase of building a new workbench, I’ll be building it out of 2×4’s Mortise and Tenon, top layers are cabinet grade 3/4” ply and 1/2” ply with Lee Valley front vice and the dog holes, both the 1/2” and 3/4”have been cut to size and was just about to cut the masonite for the very top layer but after looking at it, it wasn’t as smooth as I’d like for it to be it appeared to be a bit wavy so I put it back in my truck to be returned, I’m thinking of going with melamine for the top layer instead, thoughts on this? Should I just forego the masonite and melamine all together and just stick with the ply board? The thought process of the Masonite would be to replace it once it got beat up.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
17 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2607 days
#1 posted 06-03-2015 06:23 PM
Are you talking about just a sheet of the plastic-like melamine applied to the 3/4” plywood top, or a sheet of particleboard with melamine surface? If attaching a sheet of melamine to the plywood, it should be fine, and things will wipe up easily, and glue will have a hard time sticking to it. If you’re suggesting the particleboard faced with melamine, I would not do it.
My previous workbench had a sheet of 1/4” hardboard. I screwed it down, so I could replace it later after it got dinged up. That lasted for 2 years, and then I ended up replacing the workbench first. Have you looked at that as an option?
Blackie_
#2 posted 06-03-2015 06:29 PM
Ed, one or the other not both together and yes the particle board covered, other words the Melamine boards is what I was referring too.
I think the Masonite is the same as the hardboard, and that is what I was going to do but.. as when I got the 4×8 sheet home and started looking at it in the sunlight it had humps in it.
Blackie_
#3 posted 06-03-2015 06:34 PM
Maybe I just got a bad sheet.
Rick Dennington
6349 posts in 3432 days
#4 posted 06-03-2015 10:50 PM
Here’s some food for thought on a new bench….I built this one about 5 years ago….It is 4 layers of 3/4” MDF, glued and screwed together to make a 3” thick top…Douglas fir, m & t joinery, and 6 coats of poly…Solid bench, and dead flat…I built the under cabinet w/ drawers from an old Shop Notes design….If you want to go that route…!!
-- " At my age, happy hour is a crap and a nap".....!!
View cutmantom's profile
cutmantom
407 posts in 3272 days
#5 posted 06-03-2015 11:25 PM
Use o piece of mdf for the to layer, you can flip if over to renew it then replace it the next time
Blackie_
#6 posted 06-03-2015 11:41 PM
MDF on top of the ply it is, thanks and Rick I like the poly idea too, as for as the drawers, I need the open shelving below, but I might do a partial drawer setup.
View DocSavage45's profile
DocSavage45
8733 posts in 3080 days
#7 posted 06-04-2015 01:01 AM
Masonite is lower in density than hardboard. their is more pressure applied to harden the board.
I have used seal coat and or waterborne poly to get a more stable surface and moisture barrier on a few of my jigs and my table saw sled.
Right now I am using the collapsed cardboard in some of my plarger boxes as a surface for gluing and finishing. Then I toss it.
-- Cau Haus Designs, Thomas J. Tieffenbacher
Blackie_
#8 posted 06-04-2015 01:08 AM
Tom, I thought Masonite and Hardboard were the same, I just looked on the receipt and what I have is labeled as tempered Hardboard, so I stand corrected thanks!, once I got it home and on the saw horses ready to cut, it appeared to have small humps through out the panel, and my current workbench has a high spot in it so I’m a bit wary of it.
What I’m going to do tomorrow, is hit the hardware isle first and grab a 2” flat bar for a straight edge and gauge the sheets and if I find a good sheet I’ll go with the HB but if I don’t than I’ll go with the MDF.
DocSavage45
#9 posted 06-04-2015 01:18 AM
If there is a RE Use Store (habitat for humanity) You can find lots of goodies that might work for you. I stop in all the time after work on Wednesday. Seems prices are going up from when they first opened , but there are gems.
You got a reasonable plan there sir!
View Roger's profile
Roger
20965 posts in 3041 days
#10 posted 06-09-2015 12:12 AM
Putting poly on the top will be good because glue won’t stick to it. Drips will wipe and pop right off.
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#11 posted 06-09-2015 12:17 AM
That or wax. I have a piece of ply for glue ups and the glue just pops off
Blackie_
#12 posted 06-09-2015 12:50 AM
What I’m going to do and hope all comes out good, 3 sheets of 3/4” bottom two low grade top is cabinet grade then 1 sheet of cabinet grade 1/2 ply and top will be 1/4 hardboard, I’ll top the hard board with poly.
My glue up area I have a melamine board work station setup.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1414 days
#13 posted 06-09-2015 01:00 AM
That would make your top 3 3/4” thick (3x.75+.5+.25. If you plan on drilling holes for bench dogs and holdfasts there have been reports that sometimes holdfasts don’t hold well in thicker benchtops.
Having just worked with imported Chinese cabinet grade plywood I would suggest you avoid it. I had a lot of chipping of the face veneer and there was voids in the inner ply.
Blackie_
#14 posted 06-09-2015 01:05 AM
Hmm interesting, Yes the thickness was figured in, I had the through process of a thicker top would be a better foundation for the dogs, so are you saying WoodNsawdust that I should leave one of the 3/4” sheets out? I want to make sure I build this bench the right way having never seen nor built one before.
View crank49's profile
crank49
4032 posts in 3208 days
#15 posted 06-09-2015 05:27 AM
Mine is 4 layers of 3/4 inch sandply, then 1/2 inch MDF and topped with 1/8 inch hardboard. Banded with 1×4 Maple. All glued and screwed but the hardboard just sits on carpet tape. Can be removed/replaced if needed.
I have a problem with bench dogs holding.
But I love the big heavy bench otherwise.
Mine is 25 inches wide by 84 inches long.
Important construction note:
Be absolutely sure the top is sitting level and square and not racked or twisted when gluing up. I used winding sticks to check that mine was not twisted. Once the glue sets you have no way to correct it. A 3 or 4 inch thick top will not self correct, it will just sit there with one leg off the floor.
