Angled Dovetails?
Forum topic by JayPique posted 09-09-2009 01:21 AM 5119 views 1 time favorited 13 replies Add to Favorites Watch
View JayPique's profile
JayPique
61 posts in 3255 days
09-09-2009 01:21 AM
Do the commercially available dovetail jigs (like Akeda, PC, Leigh) allow you to cut angled dovetails? I’m interested in making a box with angled sides and was wondering if I could use dovetails. Thanks.
JP
13 replies so far
View akstudio's profile
akstudio
26 posts in 3173 days
#1 posted 09-09-2009 01:47 AM
They might, but you would probably do it in less time if you hand cut them. yes, I’m being serious. Sometimes what seems difficult by hand is really not that bad. And trying to figure a way to do it by machine can take longer to prepare than simply executing the process by hand.
Let me know if this helps.
-- Inspiring Your Passionate Pursuit of the Craft
TopamaxSurvivor
18248 posts in 3643 days
#2 posted 09-09-2009 02:00 AM
I cut them by hand on a box with all four sides tapered. Need to keep your wits about you and pay attention, buts its not too hard. I did it in pine which is quite soft and crushes easily, so they aren’t as tight as they would be in a harder wood. It was teh treasure chest for my wiffe in my projects. Good luck.
View commajockey's profile
commajockey
16 posts in 3247 days
#3 posted 09-09-2009 06:10 PM
The one dovetail jig I’ve seen that specifically markets that ability is the Keller Jig. Here's an article that shows you how to do it with that jig. I’ve never tried it personally, but it sure looks cool.
Then again, doing it by hand may be easier and comes with bragging rights. ;-)
-- Anything worth doing is worth redoing several times.
TopamaxSurvivor
#4 posted 09-09-2009 08:25 PM
I don’t have any dovetail jigs, but with a single angle it would probably work. When you get into compound angles, the jig would have to be set for the second angle too. On the single angle dovetail, the bottom would be flat just like a normal dovetail. Hope than makes sense :-))
commajockey
#5 posted 09-10-2009 02:45 AM
The Keller site does say you can do compound angles with their jig. But I don’t see where it tells you how. Seems like by the time you figure out the setup, you can learn to cut them by hand. But this is coming from a guy who’s all thumbs with a back saw.
I have the Keller jig myself and it’s super easy to use (and less expensive) for traditional dovetails, and I’ve even figured out how to do variable spacing to some degree. But by their very nature, jigs tend to limit as much as they enable.
35111 posts in 4367 days
#6 posted 09-10-2009 03:08 AM
Me’a thinkith that this is tougheth. Because of multiple angled sides. It’s a tough process. The Leigh has some papers that show how to do it, but I gave up on reading them and did a regular rabbit end joint.
Not fancy but completed the process. We were making 100 doll cradles and I figured that wasted wood for 100 cradles could be the by-product. So I went the simple route.
View thiel's profile
thiel
387 posts in 3259 days
#7 posted 09-10-2009 03:11 AM
The Akeda does angled dovetails and it shows how right in the manual. Though I haven’t done any yet, I can tell you that it looks SUPER SIMPLE on this jig: you just insert the pieces at an angle (keeping track of your faces) and you’re all set!
-- Laziness minus Apathy equals Efficiency
thiel
#8 posted 09-10-2009 03:14 AM
Actually Akeda has their manual online… near the end it shows angled dovetails. The description is brief because it’s very easy (like everything with this jig…)
http://www.akeda.com/pdf/UserManual2007.pdf
View LesB's profile
LesB
1684 posts in 3410 days
#9 posted 09-10-2009 04:48 AM
I’m almost certain the Leigh jig will do angles dovetails but I’m recouping from some minor surgery and can’t bet to my shop to check the manual. See if you can find their manual online.
-- Les B, Oregon
TopamaxSurvivor
#10 posted 09-11-2009 07:46 AM
Are you going to try it?
View BeeJay's profile
BeeJay
71 posts in 3154 days
#11 posted 09-11-2009 12:12 PM
Mate, the Leigh jig will do it but I have found as AKSTUDIO says there is a lot of buggarising about to set it up. Probably agree, its easier to do it by hand.
-- If you try to fail and succeed, what have you done?
JayPique
#12 posted 09-11-2009 11:36 PM
I’m planning on making a “dough box”, which has flared, or hopper-style sides, but I’m debating whether or not I want to dovetail it. I don’t own a dt jig right now, but I’m thinking of getting one. I see that the Akeda and Leigh jigs get the best reviews, so I’d probably go with one of those.
JP
BeeJay
#13 posted 09-13-2009 11:12 AM
There is also a router bit for the router table(if you don’t mind the concealed joinery), that can be used. The “mitre lock joint bit”. Use it often and is extremely strong. Takes a bit to set up thr firdt time. Use scrap pieces of the same size to get it right and keep them. Mark them and use them as a setup template.
