What does a Grizzly Bandsaw and a skateboard have in common?
Forum topic by Dkol posted 77 days ago 409 views 2 times favorited 3 replies Add to Favorites Watch
View Dkol's profile
Dkol
38 posts in 256 days
77 days ago
Topic tags/keywords: grizzly bandsaw bearing bearings 608zz bandsaw g0555
Bearings.
Bought a used Grizzly G0555 Bandsaw with riser block and HD mobile base last week. It was an estate item that had little use, but had been sitting for several years. Everything seemed to work fine, even though the blade was the OEM that came with the riser block. Got it home, unloaded and moved as far as the patio where it had to wait for a space to be cleared in my tiny shop. This was Thursday before Labor Day.
Friday, run up to Woodcraft and get a Timber Wolf 1/2” 3TPI blade so I can do some resawing. Get home from work, rearrange stuff and finally move the saw in the shop.
Saturday, chomping at the bit to start playing with my new toy. Started to install the new blade and discovered the blade tensioner and release not set correctly. Apparently this is quite common as the proper instructions were not included in the original manual. I had read this excellent review http://lumberjocks.com/reviews/424 when I first considered buying a bandsaw that alerted me to the problem, thanks. Got the blade on and start to adjust the guides when I find the two lower guide bearings are frozen, “crap”.
Try finding bearings on a Holiday Weekend, the hardware store did not have the right size in stack, which was goood since they wanted $11 each. All commercial sources like Grainger were closed, and Woodcraft didn’t carry them. Hit the net and noticed that the bearing # 608ZZ came up quite often on skateboard supply sites. There is a skateboard store about a mile away and yes they did carry that size bearing. Evidently that is the standard size for most skateboards and skates. There was quite a range of options $1.50 each on the low end up to $20 each for “faster” bearings.
Long story short, the cheapest bearings work fine. Got the saw up and running and got to play this weekend. Just thought I would pass on an alternative source for parts in a pinch.
View scottz's profile
scottz
21 posts in 405 days
77 days ago
For what it’s worth, the “Bones” brand “red” bearings used to be (and I assume still are) the best bang for the buck when it comes to skateboarding. They stay faster and smoother for longer than any other brand of sealed bearing that I’ve tried for skateboards and they’re on the low end of the price range.
I’ve never put them on a band saw, but I imagine the issues are pretty similar – dust is always the enemy.
View poopiekat's profile
poopiekat
253 posts in 629 days
77 days ago
Right on!
I’ve used “VXB” bearings listed in an eBay ‘store’ for all kinds of applications. Thought their main market is skateboard bearings, they have just about any bearing/bushing/linear motion assembly you might need. Just do a search in eBay for ‘VXB’...and find the seller ”Irvineman”....they’re good people. Check their eBay store listings!!
-- If Stradivarius was alive today, he'd be using Gorilla Glue.
View Kevin83's profile
Kevin83
56 posts in 263 days
58 days ago
Wow, I also just recently picked up a used Grizzly G0555 band saw with riser block… probably the same exact setup you have with the OEM blade still too. Sure enough I just realized I have the same problem as you: frozen bearing on the bottom guides. I was searching Google for “608z” bearings and kept getting skateboard supply sites, but didn’t completely believe they were selling the same part. So I changed my search slightly and this post came up. I hadn’t even thought to search LJ forums yet, but now know I should start here more often!
Thanks for the advice everyone! I’m definitely just going to stop in at a local skate shop to see what they have.
-- Kevin, Wisconsin
