Need Advice on a Mortiser
Forum topic by davidroberts posted 81 days ago 470 views 0 times favorited 10 replies Add to Favorites Watch
View davidroberts's profile
davidroberts
245 posts in 385 days
81 days ago
Topic tags/keywords: mortise benchtop mortiser mortise pal jig
I’ve been considering a dedicated mortise machine, like the delta, jet or grizzly. I don’t do production work and probably cut 50 to 100 mortises a year (maybe less) using either a router or chop them with a chisel. It’s hard to justify $300+ for a benchtop mortiser while only doing a few mortises a year, plus finding storage space when not in use. If I go the benchtop route, i’m leaning toward the grizzly or shop fox, on the grizzly website. Anyone know the pros and cons on these models. Here’s the kicker, given the cost and space allowance for a benchtop, plus the limited use, i’m very interested in the Mortise Pal http://www.mortisepal.com/. I’ve read newTim’s review, which was positive and it seems to fit the bill. Have any others out there used the Mortise Pal. Any thoughts. TIA.
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
View Mario's profile
Mario
882 posts in 950 days
81 days ago
I recently purchased a shop fox and have been very satisfied with it. It is able to pivot on its base so that you can mortice long peices. I looked at four of them isde by side and chose the shop fox, I was nervous as i have never used any Shp fox tools but it has been working well.
Give it a look.
-- Hope Never fails
View lcurrent's profile
lcurrent
38 posts in 714 days
70 days ago
I built a mortising jig that will cut a mortise on the end of a rail using a loose tenon any angle by just using a center line to line up to see photo
This is the jig http://farm3.static.flickr.com/2534/3926678251_000584e1d8_m.jpg
This some of the cuts it can make http://farm4.static.flickr.com/3420/3927467140_88e5e71d81_m.jpg
This computer table has 175+ mortises not one missed http://farm3.static.flickr.com/2548/3926659787_143ab79e7b_m.jpg
Larry
-- lcurrent ( It's not a mistake till you run out of wood )
View woodman71's profile
woodman71
60 posts in 223 days
70 days ago
I would have to say that the mortisepal looks like it will fit your needs and for the money and being able to storage it fast and out of your way looks good but I also think it come down to you if don’t think you will use it much I would look for something you can build cheap and works for you .
View socalwood's profile
socalwood
968 posts in 503 days
70 days ago
I ended up going a dedicated slot mortiser , and use the Mortise Pal occasionally . No regrets on either set up -
View woodbutcher's profile
woodbutcher
432 posts in 1065 days
70 days ago
david roberts,
I went with the shopfox mortising machine that Grizzly had on sale. It was on sale and for the money I don’t think it can beat. It has a larger chuck than most as well as the ability to be mounted and perform end mortises on any length board. Mine gets a real workout and I wouldn’t be able to get by without it. Yes it does take up some bench space, but you can always move it! Good luck on making your purchase, which ever you decide.
Sincerely,
Ken McGinnis
-- woodbutcher north carolina
25811 posts in 1299 days
70 days ago
I’ve got a different brand. It was sold by Wilke tools and they have gon out of business. I love the tool because it has a solid lockup of the wood and the wood is moved by an x-y action on the table. I only paid $189.00 as they were closing them out.
davidroberts
70 days ago
Thanks everyone. In the meantime, the mortiser decision will have to wait a while as I ran across a good deal on an old Dewalt RAS which now has my attention. By Christmas, it’s either the Grizzly or the Mortise Pal. I do want to cut through mortises which I believe the dedicated mortiser is more capable of. But I like the idea of a quick setup and storge for the Mortise Pal. Thanks again for the comments.
PS, Karson I think it was a wilke planer i was wanting to buy but could not find a distributor. Know I know why. Thanks
View RetiredCoastie's profile
RetiredCoastie
245 posts in 82 days
70 days ago
I had a Mortise attachment for my drill press and it worked OK but I got tired of setting it up all the time. I came across a brand new Jet dedicated mortising machine for $150.00 at a store closeout sale and I love it. It’s easy to set up and performs very well.
-- Eagles may soar, but weasels don't get sucked into jet engines! Mike D.
17140 posts in 476 days
70 days ago
I have a de;ta bench top and a laguna floor model they both work fine . You might see if you can find a used one.
View Julian's profile
Julian
695 posts in 424 days
69 days ago
I would try to look for a used one. They come up on craigslist around here quite often. I found an old but new looking multico brand mortiser made in germany for $200. It’s built like a tank, and will most likely outlast me.
-- Julian, Park Forest, IL
