| Forum topic by Ben | posted 81 days ago | 333 views | 0 times favorited | 6 replies | ![]() |
81 days ago |
I have a bench-top Shop Fox jointer. I noticed that it seemed to be leaving a bit of a cup on my boards (taking too much off in the middle). I took a look at the knives, and noticed that they were a little bit high in relation to the out-feed table. The out-feed table on my jointer is part of the cast, and is not adjustable, but I was able to lower the one offending blade. After making that adjustment the jointer now wants to cut wedges for me. The blades look to be the right height based on placing my Starrett ruler on the outfeed table and rotating the blades by hand – they just brush the ruler. It looked like the in-feed table was a little bit out of co-planer, which I adjusted as well (although I can’t claim that is perfect, I think it is close). I still a getting the wedge problem. What is the most likely cause? I thought at first that the front end of the in-feed table was too high in relation to the blade-end. I was not able to adjust this out, however. Could the out-feed table be warped enough to need a higher blade height? Any thoughts would be appreciated. Ben |
