Biscuit slot advice needed
Forum topic by MedicKen posted 09-08-2009 05:01 AM 2571 views 0 times favorited 28 replies Add to Favorites Watch
View MedicKen's profile
MedicKen
1612 posts in 3429 days
09-08-2009 05:01 AM
I am in the process of building an entertainment center and will be adding a face frame. I want to attach the face frame with biscuits but I dont want to go through all the trouble of marking all the slots in both the carcass and frame. I want to use a slot cutter in my router to cut the slot in the carcass and a biscuit joiner for the frame. My question/problem is the cutter for the joiner is 5/32” and the slot cutter I have is 1/8”. I know its only 1/32” difference but the biscuits are fairly snug and I am afraid that when I add glue and the biscuits swell they will split or make the plywood bulge. Has anyone used a 1/8” slot cutter for biscuits and what was the outcome?
28 replies so far
MedicKen
#1 posted 09-08-2009 05:45 AM
Pat…..I am trying to cut down the labor time involved. I had thought of sanding down the biscuits and even considered making 2 passes with the router to widen the slot. I guess I could break down and spend $15 and buy a cutter…...Novel idea huh?
View Ken Reed's profile
Ken Reed
152 posts in 3151 days
#2 posted 09-08-2009 05:58 AM
MedicKen,
Oh boy, an excuse to buy another tool!!! Whaddaya waiting for?!? If you need a tool, buy it!
(Yeah, I’m a tool whore, how did you guess?)
MedicKen
#3 posted 09-08-2009 06:07 AM
I guess I will make a 2nd pass after a 1/32” adjustment. I was just trying to save time. I did order another cutter for the next time though.
View GMman's profile
GMman
3902 posts in 3664 days
#4 posted 09-08-2009 01:54 PM
Before buying my biscuit joiner I had an attachment from sears to fit my router and I had a smaller cutter and it worked fine, I find that with my biscuit joiner the biscuit is a little loose.
http://i300.photobucket.com/albums/nn11/GMman_2008/28572-196x130.jpg
http://i300.photobucket.com/albums/nn11/GMman_2008/28615-196x130.jpg
View John 's profile
John
253 posts in 3368 days
#5 posted 09-08-2009 11:32 PM
Ken, Why use the Biscuit Jointer at all? You really don’t need it. I’ve been attaching face frames for over 20 years and have never found a real need for one with face frames.
John
-- John
GMman
#6 posted 09-09-2009 12:06 AM
John It gives some strength and mostly to line up your 2 pieces.
GMman
#7 posted 09-09-2009 12:08 AM
I have used biscuits making picture frames no nails just glue and biscuits.
John
#8 posted 09-09-2009 12:50 AM
Yeah, I know the reason that they advertise, I just don’t agree with it all that much. I bought mine about 14 years ago and I’ve only gone through maybe 500 Bisquits total. I think they’re very inconvient for face frames.
John
-- John
MedicKen
#9 posted 09-09-2009 08:04 PM
John….. I dont want to use brads or nails to hold the frame on. I am gonna paint it and dont want to go thru the hassle of filling the holes and sanding etc. The biscuits will help with allignment and keep a nice clean look and I wont have to worry about the wood filler popping out later.
View DRC's profile
DRC
8 posts in 3148 days
#10 posted 09-09-2009 11:02 PM
I recently built a kitchen full of cabinets. I used Biscuits to join/align the bottom shelf and the face frame. the sides that werent visible I used Kreg screws and nailed the top because the crown molding would cover the holes
I wouldnt use a slot cutter ina router for half your setup. Bisciut cutter for both face frame and carcas slots are neccessary because the biscuits swell with glue and do a great job holding. a thinner slot cut with your router will pucker the ply on your carcass.
Good luck. There are no real short cuts that wouldnt sacrifice something in the long run.
-- David, Fullerton CA
MedicKen
#11 posted 09-10-2009 01:55 AM
I have ordered a 5/32” slot cutter. I am thinking it will help to speed things up a little on this and other projects.
John
#12 posted 09-10-2009 02:08 AM
Ken, I never use nails, staples, screws or any other metal fastener to attach face frames, ONLY GLUE. The right glue and prep work is all you need.
John
-- John
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 3959 days
#13 posted 09-10-2009 02:29 AM
i dint read the whole post so if anyone pointed this out ken then call me a parrot but they do make a slot cutters that are the same size as biscuits
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View DaneJ's profile
DaneJ
56 posts in 3175 days
#14 posted 09-11-2009 04:40 PM
I’m going out on a limb here but, you have spent more time discussing how to get around marking the slot locations and cutting them, just sharpen your pencil and go for it… ;)
This may be insignificant but, here goes anyway, if you cut a full length slot versus the biscuit slots then you are reducing your glue surface by about one third.
-- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... Tom Waits
View GFYS's profile
GFYS
711 posts in 3437 days
#15 posted 09-11-2009 05:58 PM
In any event…if you do much bisquit joinery you’ll need a slotter the right size whether you use it for long slots or for multi tool set up for face frames etc. Good choice getting the right tool. I typically use 2 bisquit slotting jig set ups simultaniously to speed up the face frame process. One for the styles on the router/shaper table, one for the rails with a table surface mounted bisquit jointer. It saves time and reduces mistakes.
showing 1 through 15 of 28 replies
