I found a nail, with my jointer.
Forum topic by CB_Cohick posted 06-02-2015 02:51 PM 1341 views 0 times favorited 13 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
483 posts in 1121 days
06-02-2015 02:51 PM
Topic tags/keywords: question jointer blade sharpening
I found a nail in some old deck boards I am re-purposing. Not surprisingly, it did a number on my jointer blades. They all kind of look like the above picture. Are they salvageable, or should I just forget it and get a replacement set?
-- Chris - Would work, but I'm too busy reading about woodwork.
13 replies so far
View Kazooman's profile
Kazooman
914 posts in 1823 days
#1 posted 06-02-2015 02:55 PM
That looks pretty bad. It would require removing quite a bit of metal to get back to a clean edge. I think I would invest in a new set, right after I invested in a metal detector. You can get one of those really cheap at Harbor Freight.
View mahdee's profile
mahdee
3830 posts in 1638 days
#2 posted 06-02-2015 03:04 PM
It doesn’t look too bad considering the damage is close to the end of the blade. Sharpen it and move the fence past the damage area.
-- earthartandfoods.com
View SirIrb's profile
SirIrb
1239 posts in 1101 days
#3 posted 06-02-2015 03:11 PM
Find someone with a surface grinder or a sharpening service. If it is just a surface grinder then they will need a jig to hold the knives at 45. Personally I dont think it is a lost cause. 1/16 would do them a world of good.
CB_Cohick
#4 posted 06-02-2015 03:25 PM
Metal detector is a good idea I have been putting off. I went ahead and ordered a replacement set, but I will drop these off at the local Woodcraft to have their sharpening service take a look. If there is a chance to save them it would be nice to have a spare set.
4823 posts in 2363 days
#5 posted 06-02-2015 03:28 PM
Yep, the spare set is a big plus. Those may be salvageable, at least one sharpening.
MrUnix
6187 posts in 2069 days
#6 posted 06-02-2015 03:54 PM
They should be able to remove that nick as long as the knives are wide enough to allow it (ie: haven’t been sharpened a bunch already). As for the metal detector, the HF handheld works great and can be had for about $13.
PS: They also work great as a pinpointer when used in conjunction with a regular metal detector.
View Underdog's profile
Underdog
1053 posts in 1906 days
#7 posted 06-02-2015 03:55 PM
At work, I normally have three sets for machines in every day use. That way I can have one set in the machine, one set on the shelf, and one set at the sharpening service.
But I don’t use these things that much at home, so I’m lucky if I have one good set….
-- "woodworker with an asterisk"
View pintodeluxe's profile
pintodeluxe
5544 posts in 2683 days
#8 posted 06-02-2015 04:34 PM
Replace. Average quality blades are cheaper than a resharpening, and the old ones can be recycled.
View hhhopks's profile
hhhopks
650 posts in 2248 days
#9 posted 06-02-2015 05:50 PM
For the short term, you could use it as is and use your hand plane to remove the ridges.
The chip looks pretty bad. You will need to evaluate cost of sharpening verses buying a new set.
-- I'll be a woodworker when I grow up. HHHOPKS
View Ghidrah's profile
Ghidrah
667 posts in 1092 days
#10 posted 06-02-2015 07:57 PM
If mine they’d be junk, in general jointer knives are pretty cheap.
-- I meant to do that!
Kazooman
#11 posted 06-02-2015 10:25 PM
They should be able to remove that nick as long as the knives are wide enough to allow it (ie: haven t been sharpened a bunch already). As for the metal detector, the HF handheld works great and can be had for about $13.
Yep, that’s the one I bought and I can recommend it. It gets the job done just fine.
View Redoak49's profile
Redoak49
3003 posts in 1859 days
#12 posted 06-02-2015 11:29 PM
My HF metal detector has saved me several times.
CB_Cohick
#13 posted 07-02-2015 08:17 PM
Well, gentlemen, here’s the end of this story. I bought a new set of blades, and had the damaged ones sent out for grinding and sharpening. The old blades came back looking like new, and they only charged me an Abraham! I did also get one of those Harbor Freight wands with my 20% coupon. Hopefully that will prevent some future incidents. Thanks to everyone for your input.
