Table top blisters
Forum topic by enaid posted 06-02-2015 01:00 PM 733 views 0 times favorited 7 replies Add to Favorites Watch
View enaid's profile
enaid
4 posts in 1118 days
06-02-2015 01:00 PM
Topic tags/keywords: blisters table top veneer top
I purchased a dining table 8 months ago. I bought a woven placemat to put on the center of the table. I don’t use this table often so I never moved the placemat until today. I was horrified to find that the woven placemat had left blisters where there were holes. How can I remove these from this table top?
Like I said, the table is only 8 months so I hate to have to get a new one.
Thanks!
7 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1243 days
#1 posted 06-02-2015 02:07 PM
Hard to say. Are the blisters in the finish only or has the wood moved? Does the table get a lot of direct sunlight or is there a lot of seasonal change in humidity? Is the table veneered or solid wood (I’m guessing veneered)? What is the finish? You can tell the finish by dissolving a portion of it with denatured alcohol or with mineral spirits in a place that no one will see. Someone might have experience with this type of issue, but I think we’ll need more information to truly be able to help you.
-- Talent, brilliance, and humility are my virtues.
View mahdee's profile
mahdee
3894 posts in 1796 days
#2 posted 06-02-2015 02:10 PM
Looks like a chemical reaction from the “rubber” placemat and the finish. I am guessing lacquer finish on the table reacted to the plastic.
-- earthartandfoods.com
enaid
#3 posted 06-02-2015 02:31 PM
Thanks for the replies.
The table does not get any direct sunlight. I’m guessing that the top is veneered. As for the finish, I have n o idea. The blisters are in the finish only. I think mrjinx007 you are correct in stating that the veneer reacted to the placemat. I’m worried now that this is not fixable and am throwing out the darn placemats.
View pintodeluxe's profile
pintodeluxe
5706 posts in 2841 days
#4 posted 06-02-2015 04:36 PM
Someone set a hot pan on the placemat?
enaid
#5 posted 06-02-2015 04:41 PM
pintodeluxe, nope! There was absolutely nothing setting on the placemat. When I removed the placemat the bubbles are exactly where the holes where in the woven mat :-( and the shape of the mat. It looks awful!!!
View jerryminer's profile
jerryminer
928 posts in 1470 days
#6 posted 06-02-2015 05:05 PM
I think mrjinx007 nailed it. I would try talking to the vendor that sold you the table. The fix is going to be a re-finish of the top, IMHO.
enaid
#7 posted 06-02-2015 05:34 PM
jerryminer, the table (dining set) has been discontinued :-( so there is no one to contact.
I may have to check with my old contractor and see if maybe he can sand it down and then put a coating on it :-/. Thanks everyone.
