HP question for routers
Forum topic by BlazerGator posted 06-02-2015 02:52 AM 844 views 0 times favorited 2 replies Add to Favorites Watch
View BlazerGator's profile
BlazerGator
23 posts in 1273 days
06-02-2015 02:52 AM
I was reading through a thread just now about handheld routers, specifically the desirability of having 3HP to spin a panel-raising bit. Then I thought about the HP discussions regarding table saws. In those discussions, much is usually made about how the true HP of the saw is limited to just under 2HP for 110V applications, IIRC.
My question: unless, let’s say, the Triton is 220V, then shouldn’t it have the same HP limitation? I don’t recall having run across this issue in previous discussions. While I’m at it, I might as well inquire as to whether we now officially say 115/230, or is it still OK to use 110/220?
Just curious—for now, I’m sticking with my PC 690 and Bosch Colt.
-- Blaze
2 replies so far
View MrUnix's profile
MrUnix
6845 posts in 2282 days
#1 posted 06-02-2015 03:21 AM
I believe the official standard is 120/240v +/- 5% @60hz in the US, although historically, 110/220 and 115/230 have and are still used in many places.
There is a good rule of thumb chart for hp/amps at the engineering toolbox site here:
http://www.engineeringtoolbox.com/electrical-motor-hp-amps-d_1455.html
Manufacturers claimed horsepower are typically based on ‘peak’ horsepower, which is meaningless. And even the current draw is sort of misleading depending on the efficiency of the motor. Typical household 120v circuits are 15 amps, and you should stay under 80% of that for normal continuous use.
BlazerGator
#2 posted 06-06-2015 02:46 AM
Thanks, Brad.
-- Blaze
