Delta 14-650 T2 Mortiser Adapter Bushing
Forum topic by CB_Cohick posted 06-01-2015 01:35 PM 1377 views 0 times favorited 11 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
487 posts in 1336 days
06-01-2015 01:35 PM
Topic tags/keywords: question mortiser 14-650 bushing
I’m hoping somebody can help me find an adapter for my Delta 14-650 T2 mortiser. This model uses 5/8” chisels, and I would like to locate a 3/4” bushing or adapter that would allow me to use 3/4” chisels. Hopefully somebody has an idea. I called Delta Parts and they have nothing available. They referred me to Mike’s Tools and I will call them as soon as it is late enough in the day in California, lol. The other idea I have seen posted is locating a shop to have the part machined locally? Not sure how to go about that, would I just look for “machine shop” in the yellow pages? Any advice would be useful. Thanks in advance.
-- Chris - Would work, but I'm too busy reading about woodwork.
11 replies so far
runswithscissors
2804 posts in 2110 days
#1 posted 06-02-2015 12:14 AM
Hmmm. Easier to bush down that to bush up. Interesting dilemma, if I read your post correctly.
View AZWoody's profile
AZWoody
1363 posts in 1309 days
#2 posted 06-02-2015 12:17 AM
If you were looking for to do some machining, it would be to take the 3/4” shank and reduce it to 5/8”
runswithscissors
#3 posted 06-02-2015 12:26 AM
AZWoody has the right idea.
CB_Cohick
#4 posted 06-04-2015 01:47 PM
I don’t want to modify an existing part. I want a new part with different dimensions. Anyway, I think this site may have the answer.
runswithscissors
#5 posted 06-05-2015 03:49 AM
Or, just buy chisels with 5/8” shanks.
18675 posts in 1941 days
#6 posted 06-05-2015 04:00 AM
The only reason to use 3/4 shank chisels is to cut bigger mortises. The machine may not like doing that unless its soft wood. Also, how will a bushing help? Your machine has a 5/8” hole. A bushing will make the hole even smaller. If you found an adapter that would cause the 3/4” chisel to be too long and the drill bit too short. Unless I’m not understanding what you’re doing.
runswithscissors
#7 posted 06-05-2015 04:22 AM
Agreed. Like I said above, bushing down is easier than bushing up.
CB_Cohick
#8 posted 06-05-2015 12:53 PM
- runswithscissors
This is the best idea. I found some at Lee Valley that go up to 5/8” chisels with a 5/8” shank, which is the size mortise I am after ultimately. It would be nice to be able to use 3/4” chisels though if needed.
View pintodeluxe's profile
pintodeluxe
5737 posts in 2898 days
#9 posted 09-12-2015 04:25 AM
Rikon makes a clone of the Delta mortiser. The Rikon has a 3/4” bushing you can order.
I finally have a machine that will accept any size chisels, and it is really nice.
CB_Cohick
#10 posted 09-14-2015 04:59 PM
- pintodeluxe
Do you happen to know the model number of the Rikon? Got a site to order the part? My google-fu is weak this morning. I turned up nothing on a search.
View MarineCorp's profile
MarineCorp
1 post in 474 days
#11 posted 05-02-2017 09:09 PM
Go to http://www.ereplacementparts.com/search_result.php?q=23011034 and order part #23011034 bushing. This is a JET part that will fit the Delta and it is a 1”x 3/4” bushing and will take the 3/4” chisels. Price was only $8.32 plus shipping. I hope this helps.
Also look at http://www.ereplacementparts.com/jet-jbm5-708580-benchtop-mortiser-parts-c-32652_32671_32757.html
