Forum topic by noahsea | posted 09-06-2009 06:43 PM | 1499 views | 0 times favorited | 10 replies | ![]() |
hi, |
10 replies so far
#1 posted 09-06-2009 06:49 PM |
I think there are many times I rip more than 36 inches but commonly do this with ease with a 36 in fence is this what you mean by rail? Alistair -- excuse my typing as I have a form of parkinsons disease |
#2 posted 09-06-2009 06:54 PM |
If you have a choice I would definitely choose the 52”. even if you only build small projects you will still need to rip wood much longer than 36”. -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#3 posted 09-06-2009 07:03 PM |
Noah, I faced the same question when I bought my saw in April but went ahead and got the 52” rails. I routinely rip/crosscut plywood for cabinetry and, while I normally have done this with a circular saw, I really wanted to do it on my saw. Space is tight, as I have 4 feet to the left of the saw and the right side rail come within a few inches of my cabinetry. But by moving my saw forward to clear the cabinets I can cross cut a full sheet of plywood. Now I routinely do all my cuts on the table saw. This just saves a step in the building process since I do not have to worry about splintering and, of course, I can break down plywood independent of the weather. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#4 posted 09-06-2009 07:04 PM |
sorry, i wasn’t clear. shouldn’t be here before coffee. the rip fence is standard. the rail length is what i was referring to. as far as the width of stock that i rip… |
#5 posted 09-06-2009 07:07 PM |
scott, |
#6 posted 09-06-2009 08:41 PM |
I normally do not rip/crosscut any piece longer than 18 to 24 inches to the left of the blade. But if I did then I have a mobile cart that I can use to support the work piece. I normally rip/crosscut on the right of the blade and if I need to crosscut a sheet of plywood, as I did yesterday when I needed a couple of 84 inch panels for the cabinet that my wife has “commissioned”, I cut to the right of the blade where the extension table will support the piece. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#7 posted 09-06-2009 09:06 PM |
thanks for the info. nice saw, by the way. |
#8 posted 09-06-2009 09:25 PM |
plywood is normally 96”. You need the ability to cut that in half. So 52” -- "The way to make a small fortune in woodworking- start with a large one" |
#9 posted 09-06-2009 10:27 PM |
now I got you well done looks good I too would go for 52” model Alistair -- excuse my typing as I have a form of parkinsons disease |
#10 posted 09-07-2009 01:29 AM |
I went with the longer rail and setup my router on the right side of the saw with an extension table to fill out the length of the rail. This seems to be common especially if space is limited. I’ve customized different rail attachments to use with the saw guide and router for dust collection and varying the cuts. |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1419 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
