| Forum topic by Rick Boyett | posted 77 days ago | 363 views | 0 times favorited | 8 replies | ![]() |
77 days ago |
Good Morning, I’ve got a Ridgid EB4424 Oscillating belt and spindle sander. It uses 4” x 24” belts. I’ve got an idea to use this for sharpening my gouges, chisels, and planes. For my gouges, I’m planning to fasten piece of wood, with a V-groove, to the miter guage and use that to hold the gouge at the proper angle while I rotate it on the belt. The same concept can be applied to other tools too. I found a source for high grit belts at http://www.supergrit.com. They sell Black S.C. 4×24” belts up to 600 grit. I’m thinking that this might be perfect. The minimum order from Supergrit.com is $25 so I wanted to get your opinions before pulling the trigger.. Regards, |
