what's special about 31.62 degrees?
Forum topic by bent posted 84 days ago 518 views 1 time favorited 10 replies Add to Favorites Watch
View bent's profile
bent
38 posts in 568 days
84 days ago
Topic tags/keywords: question
i was recently doing some trim work with my compound miter saw, and i noticed that there’s an indicator at 31.62 degrees. i can’t figure out what this angle would be used for. can someone please fill me in on this one?
17168 posts in 477 days
84 days ago
I think thats a crown moulding angle.
View Les Hastings's profile
Les Hastings
953 posts in 673 days
84 days ago
It is a crown molding angle. There will be another odd angle on the bevel of your saw also. Don’t remember what it is at the moment. This is the compound angle to cut crown laying flat on the table of your miter saw.
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
2465 posts in 240 days
84 days ago
tilt the saw to one ( weird ) angle ,
and turn it to a different ( weird ) angle ,
and as jim says crown molding cut .
flat on it’s back , up against the stop .
very confusing with right and left ,
and inside and outside miters .
View MedicKen's profile
MedicKen
487 posts in 362 days
84 days ago
Crown moulding angle
View bent's profile
bent
84 days ago
thanks guys, i’ll keep that in mind for future use. i’ve just put an angled block behind the molding and cut it on 45’s when i’ve done it in the past. this seems quicker.
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
3072 posts in 575 days
84 days ago
I asked a cabinet maker/trim carpenter about cutting crown molding. He told me the easiest way is to do what you’re dong and touch it up with a belt sander if the angle is a bit off. haven’t goten it done yet, but I will…............someday ;-))
Edit, I forgot I have to do some 45 degree outside corners ;-((
View Ronald Coone's profile
Ronald Coone
6 posts in 242 days
84 days ago
@lumberjocks trust me – this page explaines everything about 31.62 and all other crown angleshttp://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=2
-- Ronald Coone, Florida, www.expressionwoodworks.net
TopamaxSurvivor
84 days ago
That is a good page. I think i can cut it with my table saw with that info:-))
View cabinetmaster's profile
cabinetmaster
8746 posts in 458 days
84 days ago
Bent, If you cut some crown molding that is wider than you can position on the saw fence, you can lay it flat and use these 2 angles to cut your crown.
Ronald Coone
6 posts in 242 days
81 days ago
man, you guys can make crown much more difficult than it really is. Remember upsode down & backwards. Every measure and angle you will ever need is here. http://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=2 , ps scroll to the bottom
