LF: Finger Joint Jig for Router Table
Forum topic by Zuki posted 09-17-2007 12:00 AM 11277 views 0 times favorited 12 replies Add to Favorites Watch
View Zuki's profile
Zuki
1404 posts in 4163 days
09-17-2007 12:00 AM
I want to make a couple of small boxes with finger joints in the corners. I seen two guys on the WoodWorking Channel use a jig for their router to make finger joints and it looked rather neat.
Anyone have plans for one or know where I can find plans?
-- BLOG - http://www.colorfulcanary.com/search/label/Zuki
12 replies so far
Douglas Bordner
4024 posts in 4150 days
#1 posted 09-17-2007 02:02 AM
I did a search on Lumberjocks domain, several jigs posted by VTWoody, Fred, others. Essentially it’s a box joint with thin fingers. The table saw will work better for thin fingers, but 1/4˝ aren’t hard on the router table. I’m spoiled, and do all my joints with an Incra jig.
View Thos. Angle's profile
Thos. Angle
4444 posts in 4049 days
#2 posted 09-17-2007 05:58 AM
My Porter-Cable dovetail jig has a finger joint plate with it. I haven’t used it but….........
View mot's profile
mot
4911 posts in 4123 days
#3 posted 09-17-2007 06:13 AM
Box joint jig plans number in the dozens. It’s a really easy jig to make…I googled it and came up with http://sawdustmaking.com/Box%20Joint/boxjointjig.html
This is for the tablesaw, but the router concept is exactly the same.
I use a right angle sled that rides along my router table fence. If you have a channel for a mitre gauge in your table, the above link will work with tablesaw, or router table with just a few nit picky fit things that will have to be tailor made to your setup.
I just read Douglas’ reply and that hits it on the head too.
Cheers!
View Zuki's profile
Zuki
#4 posted 09-17-2007 01:44 PM
I will take a look.
Tks
3809 posts in 4108 days
#5 posted 09-17-2007 04:55 PM
here's one
Here’s one for a router table:
There are quite a few if you want to google .
View Duckarrowtypes's profile
Duckarrowtypes
68 posts in 3991 days
#6 posted 09-17-2007 07:06 PM
If you have a routing table then I suggest looking at these. http://us.oak-park.com/catalogue.html?list=boxj--
I ordered the set of three because they’re very precise and ridiculously easy to set up.
View Bill's profile
Bill
2579 posts in 4248 days
#7 posted 09-17-2007 07:13 PM
I have those same jigs. The one problem I have found is getting consistent cuts for the joints. I do not know if it is a dull bit or too deep of a cut or what, but when sliding the piece over the router bit, it will tend to grab a little. This causes either the depth to vary a small amount, or the width. It is a small amount, but noticeable when I put the two sides together. I was using oak, and had a block behind to push them through. Perhaps it is just more practice needed, but I would like to get better results.
View niki's profile
niki
426 posts in 4166 days
#8 posted 09-17-2007 07:40 PM
I’m sure that you are not going to build one like this but…you can have a look…
http://lumberjocks.com/topics/609
Regards
niki
Duckarrowtypes
#9 posted 09-17-2007 08:43 PM
Hey Niki that’s a pretty cool jig you’ve got there. Bill: I have the same problem with the OP jigs but I too am very new to them. You’ve GOT to use a push block I’ve discovered and it really helps if you’re NOT an idiot (like me) and get a perfectly square push block.
View Zuki's profile
Zuki
#10 posted 09-19-2007 12:40 AM
MOT . . . I have yet to use my dato blade. Might be the time to give my router a rest as we had a little disagreement earlier today.
Bob #2 . . . that one from Oak Park is the one that I seen in action on the WW Channel.
Niki . . . like most, Im always amazed with the jigs you develop.
View brad's profile
brad
136 posts in 3990 days
#11 posted 10-14-2007 02:50 PM
I use Bob’s suggested method. So simple and very repeatable. If you follow the link you can see that the jig can be purchased or if you study the theory of making the join the jig can easily be shop made. They can have all their dado blades and fancy jigs…this one works everytime.
Good luck.
http://www.routerworkshop.com/boxjoints.html
-- Brad,--"The way to eat an eliphant is one bite at a time"
#12 posted 10-14-2007 05:42 PM
I can now respectfully submit this project to add to the choices for jigs.
I switched to this set up so that I would not have to “key up” several whole boards to have a set of 1/4,5/16”,3/8” 1/2” and 5/8” jigs hanging on the wall.
I can also do a style of dovetails with this as well.
