Ok a woodworking machine Alistair does not recognize?? what do you think?
Forum topic by SCOTSMAN posted 05-31-2015 06:38 PM 1055 views 0 times favorited 5 replies Add to Favorites Watch
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3822 days
05-31-2015 06:38 PM
saw this on ebay.I cannot figure out exactly how it is used and for what is it used.I know someone here will know.I hope LOL Alistair
http://www.ebay.co.uk/itm/261886572830?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
5 replies so far
View dhazelton's profile
dhazelton
2805 posts in 2533 days
#1 posted 05-31-2015 06:51 PM
From a google search it is “to set spindle tooling in a vertical and horizontal axis and it is designed to set the position of the block in relation to the shaft position on the machine having been set to your moulder. i.e. you can set the block in the same position on the moulder as on the setting stand via the dial in gauges.”
I hope you can follow that because I can’t. More of a machinists tool, I guess.
View REO's profile
REO
929 posts in 2311 days
#2 posted 05-31-2015 08:45 PM
It is for presetting molding heads. put the head on the shaft. using a template or indicators set the knives so that they are consistent with each other. remove the head and move on to the next. that way one doesn’t need to try to set the knives in the machine. once the head is installed on the machine spindles only depth of cut and cut location need be set.
View Joe Lyddon's profile
Joe Lyddon
10369 posts in 4289 days
#3 posted 05-31-2015 09:05 PM
A “Setting” Stand? Never heard of such a thing… I have no idea whatsoever of what it is. :)
View fuigb's profile
fuigb
541 posts in 3194 days
#4 posted 06-01-2015 02:38 AM
575 “pound” boat anchor. :)
-- - Crud. Go tell your mother that I need a Band-aid.
View bbasiaga's profile
bbasiaga
1242 posts in 2232 days
#5 posted 06-01-2015 04:40 AM
Recombobulating discombobulator?
-Brian
