Delta Table Saw Blade Question
Forum topic by Mark731 posted 05-31-2015 06:20 PM 697 views 0 times favorited 2 replies Add to Favorites Watch
View Mark731's profile
Mark731
3 posts in 1057 days
05-31-2015 06:20 PM
Topic tags/keywords: tablesaw blade
I just purchased a new Delta Contractor Saw (10 inch contractor saw #36-725). The directions specifically say to only use 10 blades with 5/8 inch arbor holes. I’m assuming that I can use my dado blade….just looking for some confirmation on this one before I ruin my new table saw.
2 replies so far
MrUnix
6589 posts in 2164 days
#1 posted 05-31-2015 06:27 PM
Read page 24 of the manual :)
Or just to make things easier, here is the relevant bit:
The use of a non-through cut is essential to cutting grooves, rabbets and dados. Non-through cuts can be made using a standard blade having a diameter of 10 inches or less, or a dado blade up to 13/16 inch wide with a diameter of 8 inches or less.
View jesinfla's profile
jesinfla
275 posts in 1103 days
#2 posted 06-01-2015 01:09 AM
Yes, I just bought the same saw and you can use dado as MrUnix points out.
-- They said I could be anything... So I became Sarcastic! They also said making drawers is easy... I think they lied :(
