Forstner Bit vs. Hole Saw, what do you think?
Forum topic by DocSavage45 posted 05-31-2015 06:03 PM 2060 views 0 times favorited 21 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8589 posts in 2865 days
05-31-2015 06:03 PM
Topic tags/keywords: question drill press hole saw sharpening
I just posted a forum topic regarding carbide or steel forstner bit’s, Thanks for your replies.
I also have a hole saw kit. I used this a number of times. Recently used it on my Drill Press Table build. Put the hole saw on the drill press and cut the hole. I got a lot of chatter while cutting. Did the job. I expected what happened . The hole saw cuts different than a forstner bit. More sawing action( keeping teeth unclogged while the forstner bit works more like a chisel.
Looking for your thoughts ,experience and preferences. Pros and cons?
Thanks for your input!
-- Cau Haus Designs, Thomas J. Tieffenbacher
21 replies so far
View JayT's profile (online now)
JayT
5673 posts in 2234 days
#1 posted 05-31-2015 06:39 PM
Hole saw for rough work and construction. They leave a rougher finish and are not very precise on size—they can easily be +/- 1/8” or more from the listed size.
Forstner bit for anything needing precsion and a clean finish.
DocSavage45
#2 posted 05-31-2015 06:43 PM
JayT,
my hole saw cutting has been smooth..so far, and my forstner bit (dull) splintered the pfir plywood even with a backer board. Guess Murphy’s in the shop/ But I will do some checking regarding hole size accuracy.
Thanks
View longgone's profile
longgone
5688 posts in 3331 days
#3 posted 05-31-2015 06:49 PM
A hole saw is used for cutting a through hole whereas a forstner bit can also cut a through hole cleaner and with more precision but it can also cut a hole that doesn’t go completely through your workpiece.
I have a set of Forstner bits ranging from 1/8 to 3-1/4” and they are from a mixed group of sources that I acquired over the years. I use the Irwin hole saws and like them since they seem to be the most precise …I have taken my dial calipers to the store to measure them… and are a lot easier to get the cut-out piece out of the bit after drilling.
With any of them it is important to clamp them to the table whenever possible
View CharlieK's profile
CharlieK
555 posts in 3816 days
#4 posted 05-31-2015 06:53 PM
The other advantage of a forstner bit is that you can drill as deep as needed. Of course with a hole saw you can only drill as deep as the bit will allow.
-- Adjustable Height Workbench Plans http://www.Jack-Bench.com
4999 posts in 2516 days
#5 posted 05-31-2015 07:06 PM
Everything above…I consider a hole saw a construction tool, the forstner for woodworking.
DocSavage45
#6 posted 05-31-2015 07:12 PM
Greg,
Didn’t see Irwin on Amazon. LOL! But I do have a number or their tools. Taking your calipers. Now that’s precision.
Clamping is just like sharpening. The only way to be safe.
Thanks
DocSavage45
#7 posted 05-31-2015 07:14 PM
Charlie,
Good points. My hole saw kit is shallow, and I have to cut all the way through. Recently used a 3/4 forstner bit to do a shallow indent in a cover piece.
Thanks
DocSavage45
#8 posted 05-31-2015 07:15 PM
Fred,
You’re right. But right now I have a deep set hole saw and a dull forstner bit. LOL! Same size.
As I said earlier. Sharpen, sharpen, sharpen!
Thanks
View UncleStumpy's profile
UncleStumpy
736 posts in 2336 days
#9 posted 06-01-2015 03:55 AM
Hey Doc!
Fred said it the most succinctly.
But about the dull Forstner bit…... I am a complete dork when it comes to sharpening my lathe tools but I have the chisel thing down pretty good. I just sharpened a couple of my Forstner bits and it didn’t take much. Just like a chisel, smooth and flatten the bottom, and then lightly sharpen the angle (forget the proper word). I used a smaller, smoother file and just tested the sharpness on the old fingernail. Not as sharp as brand new, but man o’ man, what a difference!
Maybe some of the other guys have a better way, but ANYTHING beats a dull Forstner bit.
-- "They don't want it perfect - they want it SPECIAL"
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#10 posted 06-01-2015 04:43 AM
Just split the circular waste with a chisel or screwdriver and pop it out. After the full depth of the hole saw is cut it becomes a pain but it’s doable. A dremel tool with a cutoff wheel it your best friend. I touch up bits all the time but mainly when I want zero tearout. Like for starting dogholes in my workbench. That being said. I have a ryobi and a HF set so it’s no big loss if its butchered while sharpening. I haven’t come close yet though.
Edit: a hole saw will work for for drilling precise holes too. You just have to account for the actual size of the finished hole and not the stated size. To prevent tear out I run the holesaw backwards for a bit. Never tried it in a drill press though. Mainly for drilling a big starter hole in finished cabinets to cut in receptacles. Rarely have it failed me.
DocSavage45
#11 posted 06-01-2015 06:17 AM
Uncle Stumpy,
As I said sharpening of all my cutting tools is on my “To Do” list.
Even checked out a pretty good video.
DocSavage45
#12 posted 06-01-2015 06:18 AM
Fridge,
Thanks for your suggestions. My hole saws have done better than my forstner bits ,,,so far. But sharpen, sharpen, sharpen??? LOL!
Thanks
View SenecaWoodArt's profile
SenecaWoodArt
434 posts in 1642 days
#13 posted 06-01-2015 09:27 PM
To me, this is a question of how large of a hole you are cutting. Rarely would I even consider a hole saw. For small diameter holes less than 1 3/4” I always use a forstner bit. Larger than than, I prefer to use a General tools circle cutter. This cutter does create a lot of burn marks, so if I need a better looking hole, I use it as a pattern and with a pattern bit in the router, I then cut my larger hole. Maybe not quite the question that you asked, but there is always more than one way to skin the cat.
-- Bob
DocSavage45
#14 posted 06-01-2015 09:52 PM
Bob.
Thanks!
my shop cats probably wouldn’t like that phrase. LOL
View Blackie_'s profile
Blackie_
4883 posts in 2536 days
#15 posted 06-01-2015 10:07 PM
Tom, you’ve been asking questions I can’t answer, glad you’re receiving good info.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
