Festool sander
Forum topic by dbw posted 05-31-2015 04:41 PM 790 views 0 times favorited 4 replies Add to Favorites Watch
View dbw's profile
dbw
201 posts in 1660 days
05-31-2015 04:41 PM
Topic tags/keywords: sander
Folks,
I need to replace my DeWalt sander and I want to buy a Festool sander. Rotex vs. ETS vs. DTS vs. RTS. Too many from which to select!! I am leaning toward a RO 90 except I’m concerned it is too small in diameter for larger flat surfaces. I am open to the idea of having 2 but which 2? Any input would be greatly appreciated. FYI I’ll be sanding bare wood typically no wider than !5” and up to 6 feet long.
-- measure 3 times, cut once
View copcarcollector's profile
copcarcollector
256 posts in 2140 days
#1 posted 05-31-2015 05:55 PM
You might check the FOG, Festool Owners Forum at www.festoolownersgroup.com There have been discussions on the various sanders there, and owners and users will be able to chime in with their thoughts and experiences as well.
Do you have a dust extractor / vacuum to hook the sander to?
Hmmm. I see you already did post over there!!
View dbw's profile
dbw
#2 posted 05-31-2015 05:57 PM
Yup. Already did. BTW I have a CT-26.
View waho6o9's profile
waho6o9
8207 posts in 2600 days
#3 posted 05-31-2015 06:12 PM
Seeing you already know what you’re going to be sanding I’d keep the consumables down
so you don’t have to purchase extras.
So, a 5” pad would be the Rotex 125, and the ETS150/5 and you could complete any sanding
tasks that come your way.
The abrasives last a long time so don’t stock up on boxes because they’re just going to sit there
a while.
Uncle Bob can hook you up and he’s one of the best of the best.
http://www.bobmarinosbesttools.com/default.asp
View cabmaker's profile
cabmaker
1735 posts in 2832 days
#4 posted 05-31-2015 06:13 PM
Dow….wise choice on the ct26
I have four festool sanders and the ets 125 is my most used
When I pull out the ro tex it is for occasions that formally required a belt sander …wouldn’t say it has replaced the belt sander but I rarely use it now
The dts is a nice sander but does not get used too much
Each model has its own niche…. Buuut if I could only have one it would likely be the ets 150/5
Enjoy the journey ! JB
