Can you poly a painted surface?
Forum topic by RandyMarine posted 85 days ago 190 views 0 times favorited 5 replies Add to Favorites Watch
View RandyMarine's profile
RandyMarine
54 posts in 268 days
85 days ago
Topic tags/keywords: question
Hello all,
Once again I seek the all knowing jock advice. I have built a large bookcase out of MDF for my neighbor. She wants it painted to match her sons room….black and white. I was wondering if I could clear coat or poly after painting to protect it and give it a smooth kind of finish. Is this a bad idea?
-- Semper Fi, Randy Sr.
View JonnZ's profile
JonnZ
4 posts in 85 days
85 days ago
While I’ve never heard of this being done, I did it myself a few years ago with some success.
I made some wooden flowers for my wife to put in a planter outdoors. She did some nice painted decoration, and we didn’t want the weather to destroy them so we topcoated with exterior poly. Worked fine, and four years later they look good as new
20793 posts in 721 days
85 days ago
Yes you can do this. I would lightly sand the bookcase after the paint has cured with 320 grit to both remove any bubbles or trapped dust particles and roughen up the surface of the paint itself. Poly bonds though mechanical adhesion so it needs a roughened surface to latch on to. Then lightly sand between coats of poly with 320 as well until you get the finish that you want for the bookcase.
Dick, & Barb Cain
7046 posts in 1199 days
85 days ago
Like Scott said poly should work.
But never use lacquer over enamel, because you’ll get an alligator finish.
RandyMarine
84 days ago
Thank you gentlemen. I appreciate the information.
View emtwoodworker's profile
emtwoodworker
22 posts in 394 days
84 days ago
Just keep in mind that poly will yellow the finish. Since part of it will be white you may want to use a water based finish.
