Ceiling-mounted fan needs to swivel
Forum topic by Brett posted 05-30-2015 08:49 PM 1111 views 0 times favorited 6 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2825 days
05-30-2015 08:49 PM
My wife bought me a ceiling-mounted fan for my garage workshop:
The fan tilts up and down, but I need one that also swivels about the vertical axis, so I can point it at my various workstations.
If you look closely at the picture, there is a short, double-threaded pipe that connects the fan bracket to the flange (the instructions say to use LocTite to glue the pipe in place). A longer pipe can be used if someone wants the fan to hang down lower from the ceiling.
I’m wondering if I can replace the double-threaded pipe with some sort of swivel adapter or something with ball bearings that would allow the fan to swivel? Any suggestions? Thanks.
-- More tools, fewer machines.
View JoeinGa's profile
JoeinGa
7739 posts in 2149 days
#1 posted 05-30-2015 09:24 PM
Perhaps you can drill and tap a hole in the outer pipe and use a thumbscrew to tighten and hold it in place?
JoeinGa
#2 posted 05-30-2015 09:25 PM
If the outer pipe isn’t thick walled enough, use JB Weld and attach a nut on the outside so you can use the thumbscrew.
View ClammyBallz's profile
ClammyBallz
447 posts in 1278 days
#3 posted 05-30-2015 09:41 PM
It looks to me like it would swivel horizontally, there’s only a nut holding the bracket on to the pipe adapter. Keeping the nut a little loose should allow it to swivel.
View Rayne's profile
Rayne
1054 posts in 1681 days
#4 posted 05-30-2015 09:46 PM
How about a lazy susan adapter. Use hardwood or ply to mount either end and it’ll swivel however you want.
This is the one I’m using for my overarm dust collection for my table saw.
http://www.woodcraft.com/Product/02Z21/Triangle-Mfg-Flat-Square-Lazy-Susan-3-516-Thick-Capacity-200-lbs.aspx
View bold1's profile
bold1
303 posts in 1989 days
#5 posted 05-31-2015 01:00 AM
What you are looking for are called Swivel Fixture Hangers. They are available at electric supply houses. Haven’t bought any for a while, but they should start at around $10 depending on the weight.
woodbutcherbynight
5559 posts in 2551 days
#6 posted 05-31-2015 01:18 AM
The lazy susan bearing will twist when the fan is on high for sure, maybe not low, but the bearing would float on the balls and still have easy movement.
Take a block of wood, drill a hole exactly the same size as the pipe and put this through the block. Put a nut, or your mounting adapter on the top of the block and mount the block across ceiling joist. It would be held in place upside down by the adapter and would not fall. The friction of the exact fit hole should allow movement by hand when pushed but not when the fan is on. Below are two pictures of the concept. I used PVC as an example only. The board should be a 2×4, I used smaller for convenience. Hope this helps.
