| Forum topic by PatP | posted 1382 days ago | 5341 views | 1 time favorited | 13 replies | ![]() |
1382 days ago |
Can somebody give me some info on Cypress wood? I have a place near me here in Fl that has quite a bit of it. I’ve never worked with anything except project grade lumber from home improvement stores so I’d like to expand my skills. What should I look for and stay away from. Thanks everyone. -- Pat>>> A Man Don't Learn a Lesson Unless It Costs Him Blood or Money!!!!! |
13 replies so far
#1 posted 1382 days ago |
Cypress has a natural oil in the wood so it can be a pain glueing. you probably need to wipe down the parts to be glued with Lacquer thinner to remove the oils. It’s a soft wood and a light wood. I’ve made a couple of benches with it and I didn’t finish them, I’m letting them age in the weather. one is about 4 years old now and the other is 3 years. In my part of Delaware they were used mainly for shingles in the colonial times. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#2 posted 1382 days ago |
it is very soft, scratches and dents easily. But its cheap, thats why I use it a lot. -- David South FLorida http://ahunkahunkaburninlove.blogspot.com/ |
#3 posted 1382 days ago |
Cypress is also used in some flamenco guitars. It is typically used for the back and sides, and has a beautiful yellow color. I have one and it has held up now for more than 30 years. -- Sam |
#4 posted 1381 days ago |
About 50 years ago my Dad, Uncle and I (as a 11 year old so-called helper) built a cypress Pirogue and it is still in use today. I have also built cypress outdoor furniture that weathers nicely to a grey finish without requiring a finish. I also have a cypress headboard I built that was under water for 3 weeks during the Katrina flood in 2005. All I had to do was let it dry out to about a 12% moisture content and refinish it. My wilfe and I still use it in our house. Although it is a soft wood and will scratch easily…it is most certainly durable. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#5 posted 1381 days ago |
Isn’t Cypress known for it’s natural resistance to bugs and rot because of the oils? Just keep the parts bulky and expect it to get dinged up. The rustic look is ideal for this wood. -- "They who dream by day are cognizant of many things which escape those who dream only by night." ~ Edgar Allan Poe |
#6 posted 1374 days ago |
I have worked a lot of Cypress over the years. I hand carve all our outdoor signs out of Cypress. My home was built in 1974 of solid Cypress, studs, floor joist, beams that run the complete length of my home, ceiling,more or less everything except the finished floors and cabinets. We consider Cypress to unstable a wood to build kitchen cabinets with especially raised panel doors. Two things that do not like Cypress…water and bugs. My house has never had an exterminator in it and only on occasion do we see a bug crawling across the floor. I have no rot anywhere and it’s never had any kind of finish applied to it. I also build wood counter tops with Cypress, play with it a little and you would be surprised how you can stain or dye it and make the grain pop in your face and put a smile on your face. bruc -- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com |
#7 posted 1374 days ago |
I am just finishing my first Adirondack chair using left over cypress fence boards. Does anyone know if it is safe to burn in a campfire and possibly roast smores over? I have several fence boards left that are so warped they can’t be used for much, but a I can’t bring myself to throw them out. -- ShawnH "In matters of style, swim with the current. In matters of principle, stand like a rock." Thomas Jefferson |
#8 posted 1374 days ago |
Never roasted anything over it but sometimes I bring some of the scraps in and throw them in the wood stove and burns ok and not seemed to have poisoned anyone of our neighbors. bruc -- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com |
#9 posted 1373 days ago |
I seem to recall reading/hearing that the bug/rot resistant portion of cypress is either the sapwood or the heartwood – that the other isn’t nearly as resistant. Now if I could only recall which it was – the sapwood or the heartwood. I must have killed too many brain cells when I was younger – I now have CRS syndroms (Can’t Remember S*#&)! Jim -- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life". |
#10 posted 1373 days ago |
Cypress reportedly has a natural resistance to termites etc. I find it very difficult to work due to its instability and high oil content. The tendancy to split and tear is not an attraction to me either. It has to be very very dry before it is really useable. Can be used when laying plies etc as the process helps to stabilise it. Not one of my favourites. -- If you try to fail and succeed, what have you done? |
#11 posted 1372 days ago |
I use cypress in all my outdoor / patio furniture projects. Most people love the color or appearance of the wood. It does age to a dull gray if left unfinished and some people want that. A water sealer will do just fine at keeping the color almost natural. For indoor projetcs it is sensitive to moisture and will expand and contract all the time. You must allow for such movement. -- Cajun Don, Louisiana |
#12 posted 1372 days ago |
Most of our home is made of cypress (timbers, plank flooring, T&G on walls, exterior siding). It is easy to work, and does have a natural resistance to bugs and decay. I didn’t put any finish or sealer on our exterior lapped cypress siding… just used a vineger + steel wool mix to speed up the greying of the wood for a weathered look. Some of the leftover timber blocks have been laying outside on the ground for a few years now, and are still in good shape. However, I have noticed termites in a couple of pieces that I flipped over. Perhaps due to the constant contact with the ground over the years (maybe the cypressine oil is able to leach out / the wood becomes less resistive). Or, and more likely, it is mostly sapwood. ((Even old growth pine had some degree of termite resistance, so I would imagine heart cypress is especially resistant.)) As far as looks, it’s tough to distinguish it from pine in my opinion. -- Frank, Mississippi, Handcrafted wooden rings - http://www.bentwoodrings.com |
#13 posted 793 days ago |
Cypress is an awesome wood to work and can be quite attractive. It’s a softwood so design your piece accordingly. |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2905 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
