Need help identifying a lathe part
« back to Woodturning forum
Forum topic by kevinbradshaw posted 05-30-2015 12:45 PM 1309 views 0 times favorited 9 replies Add to Favorites Watch
View kevinbradshaw's profile
kevinbradshaw
26 posts in 1395 days
05-30-2015 12:45 PM
Topic tags/keywords: lathe
I bought this used lathe, I’m a complete newbie and I need to make sure I understand some of these parts.
Craftsman 113.228160
This part in particular. I believe the end of this is an MT1 cup center, missing the center point. If this is correct, then it is seriously rusted in there. I want to make sure that’s what it is before I start hitting it with Liquid Wrench and a mallet.
-- Kevin - Tampa, FL
9 replies so far
View Bmezz's profile
Bmezz
41 posts in 1289 days
#1 posted 05-30-2015 01:45 PM
Put the liquid wrench to it for a while. If it is morse tapered there should be a hole through the back of the tailstock to insert a knock out rod. Gently tap from that end and it should come out. If you don’t have a knockout rod get a 10” nail and grind the end flat. Also some tail stocks will eject a centre when you retract the spindle all the way. I have no experience with that particular lathe but others should be along with specific experience. Good luck.
-- Member Valley Woodturners Ottawa. Member AAW
View LeeMills's profile
LeeMills
506 posts in 1207 days
#2 posted 05-30-2015 01:49 PM
That is what it looks like to me. I would give it a good soaking in penetrating oil; rather than use a mallet and maybe mess up the quill I would put vice grips on it and try to loosen it that way.
I have a craftsmans dead center that looks the same and the hole on the side should be for a set screw to a moveable point. I would trash the dead center and get and new live center for <$20.
As rusty as the quill is I would disassemble and clean good or it will always be a bugger to move.
Edit> I had a Jet that looked about the same with the wheel for the quill in the tailstock body. There is a good chance the quill is not hollow (or hole through the tailstock). I would soak the quill good also before you try to move it much, the plastic wheel can be broken fairly easily if the quill is frozen in also.
Bmezz
#3 posted 05-30-2015 01:53 PM
Just checked the manual on vintage machinery.org. It is hollow and it suggests using a 1/4 dowel or brass rod as a knockout.
kevinbradshaw
#4 posted 05-30-2015 02:16 PM
Thanks guys. That’s what I was going to try, poking something through the back. I just wanted to make sure I knew what I was looking at.
I’ve already ordered a live center, spur center and a new belt. Just have to mount it and find room in the garage and I should be in business.
MrUnix
6353 posts in 2105 days
#5 posted 05-30-2015 05:00 PM
What Bmezz said. When all else fails, read the manual:
From page 18:
5. To remove the center insert a 1/4” wood dowel or brass rod through the hole in the tailstock ram. Hold the center with one hand and tap the dowel or rod with a hammer.
kevinbradshaw
#6 posted 05-30-2015 06:33 PM
Thanks guys.
I read the manual, I just wasn’t sure I was hitting the correct part with the dowel.
View RogerM's profile
RogerM
790 posts in 2305 days
#7 posted 05-31-2015 01:26 AM
This is a spur that goes in the tail stock and has a #1 Morris Taper on it. It is wedged into thecylindrical tail stock (and probably rusted) so put a little liquid wrench on it wait for an hour or so and drive it out with a hammer and punch or similar device.
-- Roger M, Aiken, SC
kevinbradshaw
#8 posted 05-31-2015 09:04 PM
Success!
kevinbradshaw
#9 posted 05-31-2015 09:12 PM
I sure hope the inside of the quill is ok.
