how do you use a 3" screw end forstner bits?
Forum topic by distrbd posted 05-30-2015 12:36 PM 1628 views 0 times favorited 16 replies Add to Favorites Watch
View distrbd's profile
distrbd
2252 posts in 2408 days
05-30-2015 12:36 PM
I,m not a big fan of screw end forstner/saw tooth bits , the one I had to use yesterday was a 3”, I set the drill press on 500 rpm , clamped the 1” thick plywood well but as soon as the tip of the screw hit the wood it wouldn’t let go of it and screwed itself to the wood so tight that I had to turn off the drill press to stop it all.
I ended up removing the center bit(screw) and used the saw tooth bit on its own and it worked but what’s the point of having that screw in the middle of the bit?
What am I doing wrong here?lower rpm ?hand held drill?
-- Ken from Ontario, Canada
16 replies so far
View JayT's profile
JayT
5585 posts in 2173 days
#1 posted 05-30-2015 01:18 PM
Wrong application.
Those bits are called self-feeding bits and are mainly used by plumbers and electricians for boring holes through studs, joists and other framing members to run pipe and conduit. The screw tip pulls the bit into the wood since it’s very difficult to get enough pressure behind a drill when it’s in the tight space between joists to use a hole saw. They work very fast, but not very clean—lots of blowout on the back side.
distrbd
#2 posted 05-30-2015 01:28 PM
What tool are these bits used with? hand brace drill maybe?
This is the set I got ,used the largest bit which is 3”:
Grizzly H5982 Forstner Bit 9-Piece Set, 1-3-Inch
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#3 posted 05-30-2015 01:40 PM
All Forstner bits are best used in a drillpress. You could grind the threads off of those screw spurs and just grind a sharp point on a shorter spur.
distrbd
#4 posted 05-30-2015 01:53 PM
- gfadvm
I never thought about grinding the screw to get rid of the threads, I came up with another solution while typing this post, how about drilling a pilot hole a size bigger than the bit so the threads don’t grab on to the wood so tightly? but that is an extra step, I like your idea of grinding the center screw .
Thank you Andy.
View ChuckV's profile
ChuckV
3109 posts in 3489 days
#5 posted 05-30-2015 02:06 PM
I think that it will be hard to get a clean cut with just the one cutting edge. You probably want something like these:
http://www.leevalley.com/US/shopping/AddViews.aspx?p=45541
My set is from Rockler and I have been very happy with them.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View johnstoneb's profile
johnstoneb
2857 posts in 2134 days
#6 posted 05-30-2015 03:01 PM
JayT +1
-- Bruce, Boise, ID
View Ghidrah's profile
Ghidrah
667 posts in 1184 days
#7 posted 05-30-2015 03:02 PM
Plumbers and electricians tend to use HD right angle drills
-- I meant to do that!
View TheFridge's profile
TheFridge
9249 posts in 1448 days
#8 posted 05-30-2015 03:07 PM
I drill a pilot hole sometimes. Usually if I need to use an electric drill.
View JayT's profile
JayT
#9 posted 05-30-2015 04:47 PM
- distrbd
- Ghidrah
Yep, something like this.
View JoeinGa's profile
JoeinGa
7735 posts in 1969 days
#10 posted 05-30-2015 04:54 PM
I have a complete set of the same type by Makita. That screw tip center bit will unscrew to be removed from the bit. I take the screw tip out and use one that I ground down to a nib when I need to use these. It’s a bit “jumpy” at first but in the drill press it’s not too bad so long as the work is clamped down.
View jerryminer's profile
jerryminer
916 posts in 1403 days
#11 posted 05-30-2015 06:38 PM
Sell those bits to your local plumber and get a set of actual Forstner bits.
distrbd
#12 posted 05-30-2015 07:20 PM
these bits are obviously not for woodworking the way they are, I don’t get why Grizzly is selling them without mentioning what their intended use is, I will however try to grind the threads and reshape the tips.
I just tried the bit with a larger pilot hole and it worked fine.
thank you all for your help,Tjay,thanks ,I learned something new today.
runswithscissors
2724 posts in 1987 days
#13 posted 05-31-2015 03:54 AM
Those big diameter bits can be dangerous used in a heavy duty low speed right angle drill. When the bit hangs up, it can break your wrist. They usually have a threaded hole in the gear head for an auxiliary handle made from a piece of pipe. Better yet, some now come with a clutch on the low speed setting, including the Dewalt, more recent Milwaukee Hole Hawg, and the old Black and Decker Timberwolf (from the days when B&D made actual industrial quality tools).
TopamaxSurvivor
18241 posts in 3638 days
#14 posted 05-31-2015 05:34 AM
That is definitely what we used to call a planetary bit not a Forstner bit. They are used by electricians and plumbers. They are nearly worthless without the feed screw. ;-) Putting one of those in a Milwaukee Hole Hog and hitting a nail or knot is not for the faint of heart ;-))
distrbd
#15 posted 05-31-2015 01:49 PM
Thank you all,I have been urged by members from another WW site to contact both Amazon and Grizzly and see if they can replace these plumbers bits with actual forstner bits.
As I mentioned before, when I ordered this set I searched for large forstner bits, found this set, I assumed they are like my smaller set made for woodworking,I never looked at the center bits in them to see if they had brad points or not. so you you know what they say about assuming anything .
