Play in Miter Saw Blade
Forum topic by Divotdog posted 82 days ago 183 views 0 times favorited 2 replies Add to Favorites Watch
View Divotdog's profile
Divotdog
36 posts in 338 days
82 days ago
I have a 12 incn compound Ryobi miter saw, which I bought for very little. The blade was horrendous so I got a nice Freud blade with more teeth than Carter has pills. It creates a very smooth cut but it has some play in it – maybe 1/32, not real sure. It seems to be cutting straight but should I be concerned about the play? Or maybe I am cutting just crooked enough to come out straight? (:>
I removed and reinstalled the blade to be safe. It has a 1 inch arbor – should it be shimmed? Also I just noticed my Dewalt T/S also has some play in the blade but not as much. Who says there are no stupid questions?
-- David, Dallas,Tx - golfing weather is nice but so is woodworking!
2429 posts in 237 days
82 days ago
maybe you need some blade stabilizers .
View LONGHAIR's profile
LONGHAIR
49 posts in 710 days
82 days ago
If you are refering to “play” as side to side movement, by hand with the saw not running, assuming that the blade is indeed tight…..shimming won’t help you. It is the motor’s arbor (shaft) that has the free-play. It is loose with-in the housing and there probably isn’t much that can be done. I doubt that you could find anyone who is willing to work on it….or get parts for that matter.
It may be a case of the motor actually stabilizing it as it runs though? If it cuts ok, (repeatable) it may not be a big deal.
