Anyone ever use one of these?
Forum topic by Mikeyf56 posted 09-04-2009 02:48 AM 921 views 0 times favorited 4 replies Add to Favorites Watch
View Mikeyf56's profile
Mikeyf56
171 posts in 3123 days
09-04-2009 02:48 AM
Feedback?
http://www.rockler.com/product.cfm?page=21345&filter=cmt%20tray%20template
I am wondering if it might be simple to make the templates, and just buy the router bit and collet extender separatley….
-- Powered by Smith & Wilson~~~
35099 posts in 4302 days
#1 posted 09-04-2009 03:04 AM
The templates don’t look like a big job. It would be interesting to see what the router bit looks like.
13594 posts in 3243 days
#2 posted 09-04-2009 03:13 AM
buy the bit and extender separately , ( unless they are cheaper in the set ) .
if you want to make bigger things , use them in a router table ,
and make your own templates .
i just looked again , and it appears the set is cheaper ,
their router bits start at around 60 bucks for specialty bits
their template is just mdf , easy to replicate , and you can make any other type you want .
View miles125's profile
miles125
2180 posts in 3907 days
#3 posted 09-04-2009 03:17 AM
Looks like a plunge router with collets and your own MDF patterns would do the same thing.
-- "The way to make a small fortune in woodworking- start with a large one"
View northwoodsman's profile
northwoodsman
242 posts in 3648 days
#4 posted 09-04-2009 03:35 PM
I just purchased it earlier this week. I had a 20% off coupon from Rockler which saved me $20. The bit and the collet extension will cost that much. It comes with a DVD that explains the process in detail. The first thing I am going to do is make extra copies of the patterns and also a single piece full size pattern. If you use it as is, you have to keep moving the template and screwing it in place to hold it to make a 2 or 4 compartment tray/bowl. Instead of following the DVD however, I’m going to cut the outside edge down to size first using a circle/elliptical guide (on sale yesterday at Rockler in the “Deal of the Day” for $39.99, which was $50.00 off), then clamp the template to the round disc. This will eliminate having to cut the outside edge to size on a band saw and then sanding it to a perfectly round shape after the compartments have been routed.
Cincywoodworker posted this earlier this week: http://lumberjocks.com/projects/20792.
If you finished the bottom nicely, you could flip it over and use it for a cheese board/bread board. I would rout a nice profile on the outer edge on the bottom for that purpose.
-- NorthWoodsMan
