Making a chair sit flat
Forum topic by SuperDave0002 posted 87 days ago 456 views 0 times favorited 9 replies Add to Favorites Watch
Rockler
View SuperDave0002's profile
SuperDave0002
43 posts in 131 days
87 days ago
Does anybody have a secret, quick and easy way to square up a 4 leg chair so it sits flat without rocking? I have an idea how to, but would like some othoer options, just in case they are better than what I am thinking of doing.
Thanks David
-- David South FLorida
View MaxS's profile
MaxS
46 posts in 94 days
87 days ago
Find a flat surface. (Top of a tablesaw would be good). Put your chair on the surface. Put a piece of course sand paper grit side up between the top and the chair-leg-that’s-to-long and sand it down until all four legs are even. (You might have to do this to more than one leg…but you get the idea).
-- Socrates: "I drank what?"
SuperDave0002
87 days ago
A+ Thanks Max It worked perfectly, Only took a couple of passes along the saw to make them flat as can be.
View miles125's profile
miles125
1443 posts in 906 days
87 days ago
But sometimes you need a crooked chair if the floor demands it. Wink
View Brian's profile
Brian
54 posts in 612 days
87 days ago
A much faster way is a tip from a video I saw (but can’t remember where).
You set the tablesaw blade just slightly protruding above the table and you pass the chair-leg-that’s-to-long over the spinning blade. Waaaay faster than sandpaper..lol
-- http://www.brianpenning.com/
View ajosephg's profile
ajosephg
443 posts in 461 days
87 days ago
lol Brian. If I did it that way the legs would probably be only six inches long befoe I got it right.!!
-- Joe
View MaxS's profile
MaxS
46 posts in 94 days
87 days ago
Cool. Glad it worked out. Cheers.
View Rich99's profile
Rich99
48 posts in 72 days
54 days ago
i’d be sanding for a long time…
-- Far-North Wood-Works (a fantasy company)
View Sawdust2's profile
Sawdust2
1190 posts in 988 days
54 days ago
Thjat’s fine if you just have to even one leg.
Check out my review of the MultiMaster and the SonicCrafter if you have to shorten all 4 legs.
http://lumberjocks.com/reviews/932
View BTKS's profile
BTKS
492 posts in 364 days
54 days ago
What about adjustable feet, just for those times the floor isn’t flat either? Costs more but not much. Just my .02, BTKS
