Drum Sander what kind of paper?
Forum topic by rwe2156 posted 05-28-2015 11:34 AM 965 views 0 times favorited 8 replies Add to Favorites Watch
View rwe2156's profile
2844 posts in 1416 days
05-28-2015 11:34 AM
I have a few questions if you could address each one but not brag about your machine LOL??
1. Cloth, paper, felt backs? Diffs/preferences
2. Alum oxide, zirconia?
Its for a Grizzly dual drum sander.
One first drum is metal the second is covered with felt
I’ve always ordered the 6” rolls Grizzly recommends ( I believe Steelex).
3. Other brands use 3” wide rolls. Any advantage to switching?
4. I have a big problem with the belt loosening (mostly on the unlined drum I believe because of heat build up).
5. I’m thinking there might be a way to use hook and loop paper if I could line the drum with the “hook” part.
Any ideas about that?
8 replies so far
View RRBOU's profile
170 posts in 2228 days
#1 posted 05-28-2015 01:33 PM
Grizzly makes a hook and loop conversion for their drum sanders. I have the duel 24” z series and love it. It came with the hook and loop drums. You can use any width paper you wish. Just figure the circumference of your drum, For instance a 6” drum is 18 7/8” lay a straight edge on the paper and cut from one side to the other in a straight line that is 18 7/8” this will give you the taper. Wrap the paper around the drum and mark the other end then do the same. after you have a template just lay the old paper on a new sheet and cut. I have used 6”, 4” and 3” paper. Have not noticed any difference in performance but the price will very.
-- If guns cause crime all of mine are defective Randy
View TheFridge's profile
9110 posts in 1421 days
#2 posted 05-28-2015 02:09 PM
View Woodbum's profile
804 posts in 3001 days
#3 posted 05-28-2015 02:17 PM
3” rolls plain cloth backed from Peachtree on my”*” drum sander. I cut the belts myself. Sorry about naming Peachtree and not the 16-32 sander but I’m not bragging about them, the sander, or me cutting my own belts; being the modest old guy that I am. LOL.
-- "Now I'm just another old guy wearing funny clothes"
#4 posted 05-28-2015 02:31 PM
Marvelous. Thanks for the info.
Just ordered some paper but I’ll definitely do the conversion after I’ve used up my paper!!
View ScottKaye's profile
605 posts in 1888 days
#5 posted 05-28-2015 02:43 PM
I know quite a few people around here order from Industrial Abrasives.
They have a wide selection of everything abrasive. It is so much cheaper to buy a roll and cut your own paper. They will even sell you custom size rolls (which is what I did) at no extra charge. here is a link to a review I did here on Lumberjocks
-- "Nothing happens until you build it"
#6 posted 05-28-2015 04:18 PM
Ordered the H&L conversion kit and got some small rolls of AO and Zirc from Super Grits to try out.
What I’m trying to do is surface some figured white oak veneer I am cutting myself.
I find my biggest problem is heat build up in the drums, which loosens the paper.
View gfadvm's profile
14940 posts in 2625 days
#7 posted 05-29-2015 12:32 AM
Aluminum oxide is the preferred abrasive for wood. The zirconium is used primarily for metal. I buy the 3” bulk rolls from Industrial Abrasives and cut my own (always have trouble getting the right tapers). I’m trying RRBOU’s method the next time!!!
View ClammyBallz's profile
428 posts in 1072 days
#8 posted 05-29-2015 08:51 PM
When I had my Jet 16/32, I bought rolls form Industrial Abrasives and cut my own.
I ordered a supermax 25” dual drum sander, due for delivery on Wednesday and ordered more rolls from IA for it.
