Help with a mantle
Forum topic by David1982 posted 05-28-2015 03:54 AM 856 views 0 times favorited 10 replies Add to Favorites Watch
View David1982's profile
David1982
5 posts in 1461 days
05-28-2015 03:54 AM
Im going to be making a mantle to sit over top of the current mantle on my fireplace. It will be a 8” x 10” beam 7’ long that I want to cut a large rabbet into. 6 1/2” x 6 1/4”. Im just getting back into woodworking and I need help. I don’t want the rabbet to extend all the way to the edges of the beam. I want it inset 3” from either end so as to hide the cut from the side. My problem is my table saw won’t cut deep enough, and I’m unsure of how to finish the cut on the inside corner of the rabbet. I tried attaching some photos, hope they load. If anyone can give me some advise I would appreciate it. I can email the photos of what I’m trying to do if they didn’t load here. You can also reach me at davidthompson1982@gmail.com
Thanks guys in advance for the advise.
David
10 replies so far
View esmthin's profile
esmthin
77 posts in 1150 days
#1 posted 05-28-2015 04:59 AM
The only thing I can think of is to cut what you can with the table saw, then finish the rest with a chisel. That’s what I would do.
-- Ethan, https://instagram.com/ethan_woodworker/
David1982
#2 posted 05-28-2015 01:13 PM
That would be fine, however my ts only cuts to a depth of 3 1/4”. The two cuts I need to make are 6 1/2” and 6 1/4”.
View Bill White's profile
Bill White
4909 posts in 3929 days
#3 posted 05-28-2015 02:04 PM
Router and chisels.
Bill
-- bill@magraphics.us
View TheFridge's profile
TheFridge
9252 posts in 1455 days
#4 posted 05-28-2015 02:22 PM
use a table saw to cut an inch of depth at a time on each side and a multi tool to finish the saw cuts and cut the ends to release the waste piece. I say only an inch at a time because a multi tool has only so much reach with its blade.
Once you get to where you only have a 1/4” or so left the. Make your final cut with your table saw, be careful with the multi tool, and use a wide chisel to clean up the rest.
I’d prob make a spline cutting jig to crosscut the ends clean then finish up with a chisel.
View Kazooman's profile
Kazooman
1001 posts in 1921 days
#5 posted 05-28-2015 03:15 PM
I have a thought on how to do this, but it is potentially dangerous. So…... Don’t this on my say so, but it might jog someone else’s thoughts for a safer solution.
Use your table saw or a good circular saw to make the cuts as deep as you can right up to your layout lines. This will give you clean edges where the ends and front of the piece meet the existing mantel. Then CAREFULLY cut inside these lines to the required depth with a small chain saw. The bulk of the waste should pop right out. Then clean up the interior with a chisel. It will never show so it doesn’t have to be perfect. The clean edges from the table saw cut will keep the piece in place with no problems.
View Daruc's profile
Daruc
460 posts in 1102 days
#6 posted 05-28-2015 03:18 PM
I would do it with a sawzall.
View madts's profile
madts
1855 posts in 2309 days
#7 posted 05-28-2015 05:50 PM
Make it out of 4 pieces of wood, all with 45 deg. angles. If done right it will look like one piece of wood.
Madts.
-- Thor and Odin are still the greatest of Gods.
View jerryminer's profile
jerryminer
917 posts in 1410 days
#8 posted 05-28-2015 06:22 PM
Looks like a chainsaw project to me. Tablesaw and router won’t even get close.
If it were me, I’d cut close with a chainsaw, breaking out chunks as I went, then finish with an angle grinder with a carving disk, and probably a chisel to clean out the inside corners.
View pintodeluxe's profile
pintodeluxe
5624 posts in 2782 days
#9 posted 05-28-2015 07:16 PM
You can make a built-up beam, and either miter the corners or else cover the glue lines with a thin veneer piece of matching lumber. That way the TS will be able to make the cut with a 8” dado set.
This Mantel beam is a glueup of 4 pieces, and even up close I can’t see the jointlines.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2339 days
#10 posted 05-28-2015 07:39 PM
I second the opinion of making it out of more manageable pieces. I wouldn’t attempt to do that on a table saw. That’s about 47 board feet of material, assume its dry and comes in around 4lb per board foot, that’s almost 200 lbs. If you already have the wood, I agree with roughing it out with a chainsaw, and then cleaning it up with chisels.
